..good to hear.. that it works.. Tomorrow I will release a new version some bugs and enhancements (multiplier for e.g. Watt to kWatt i.e. /1000)
in order to support these devices, I need the device properties, here is how to get them:
create a new action group / server action /script and file action/ embedded script
enter command:
indigo.server.log(str(indigo.devices["xxx"].states.keys())) replace "xxx" with your device names one at a time, click on <run>
Then get the log file output
it should look like (this one is for a thermostat):
[u'hvacCoolerIsOn', u'hvacDehumidifierIsOn', u'hvacFanIsOn', u'hvacFanMode', u'hvacFanMode.ui', u'hvacFanModeIsAlwaysOn', u'hvacFanModeIsAuto', u'hvacHeaterIsOn', u'hvacHumidifierIsOn', u'hvacOperationMode', u'hvacOperationMode.ui', u'hvacOperationModeIsAuto', u'hvacOperationModeIsCool', u'hvacOperationModeIsHeat', u'hvacOperationModeIsOff', u'hvacOperationModeIsProgramAuto', u'hvacOperationModeIsProgramCool', u'hvacOperationModeIsProgramHeat', u'setpointCool', u'setpointCool.ui', u'setpointHeat', u'setpointHeat.ui', u'temperatureInput1', u'temperatureInput1.ui', u'temperatureInputsAll']
do this for all your device properties you like to add, what they mean and also what they should be called. don't bother with xxxx.ui types.
eg i replaced hvacFanIsOn with FAN-ON to be presented to the users.
so at the end I need a list that looks like:
"property" : "property-niceName"
If you could do it in this format I save some typing
here the list I currently have:
"hvacHeaterIsOn": "Heat-ON"
,"hvacCoolerIsOn": "AC-ON"
,"hvacFanIsOn": "FAN-ON"
,"setpointHeat": "SetPointHeat"
,"setpointCool": "SetPointCool"
,"temperatureInput1": "Temperature"
,"temperature": "Temperature"
,"temperatureF": "Temperature[F]"
,"temperatureC": "Temperature[C]"
,"humidity": "Humidity"
,"accumEnergyTimeDelta": "EnergyMeasuremtTime"
,"accumEnergyTotal": "Energy[Watt-Hour]Total"
,"curEnergyLevel": "Power[Watt]"
,"hvacDehumidifierIsOn": "Dehumidifier-ON"
,"hvacHumidifierIsOn": "Humidifier-ON"
,"rainrate": "Rain-Rate"
,"currentDayTotal": "Rain-Today"
