after moving to new mac plots doe not show data
Fri Oct 12, 2018 10:28 pm
Re: after moving to new mac plots doe not show data
This must be a directory issue.
Do you have a time machine backup?
You can use a file from there
Move the file to that directory select it and run it.
Sat Oct 13, 2018 4:54 pm
hamw offline
Well, I did not have time machine set up as I have found it to be a bit buggy in the past. I have an automated whole disc backup nightly, and compress/archive the entire Indigo file when I get through major changes, so I thought that would be good enough. However, since IndigoPlotD keeps its restore files outside of the Perceptive Automation folder, I didn't have an archived copy. Anyway I set up time machine on my NAS (finally) and fortunately the plot structure was all still there in the plot devices, so all I had to do was reconfigure the devices and sources and we are back up and running.
Thanks again for a remarkable plugin!
Ham
Sat Oct 13, 2018 5:04 pm
I added the indigo directory many years ago as i did not want to touch the perceptive automation directory.
That philosophy has changed now, but it would be a bit of work to move everything ..
and i have my ~/indigo directory in my backup path. ALL my plugins store stuff there .
