Python version not available after 12.3 upgrade
Sun May 15, 2022 1:51 pm
DVDDave offline
I just updated to Indigo 2022.1 and then to OS 12.3.1. I was able to workaround all minor issues but I'm not sure about this one. I get the following error when INDIGOplotD starts up:
   INDIGOplotD Error               FATAL error:  none of python versions 2.5 ..2.8 is installed  ==>  stooping INDIGOplotD
Then I get these errors every 10 seconds:
  File "plugin.py", line 9002, in runConcurrentThread
  File "plugin.py", line 9020, in dorunConcurrentThread
  File "plugin.py", line 6549, in checkIfEventData
AttributeError: 'Plugin' object has no attribute 'DEVICE'
I thought 2022.1 had a workaround to allow Python2 based plugins to run but apparently not in this case. Any suggestions to get this great plugin working again? Thanks!
--Dave
Sun May 15, 2022 3:49 pm
This is nothing to do with Indigo 2022.* as such.
The plugin checks /usr/bin for either python2.6, python2.7, python2.8
The indigo installer doesn’t delete those; you’re correct that 2022.1 still supports 2.7
Can you check that folder? Have you tidied up python or Indigo versions/folders?
Sun May 15, 2022 4:02 pm
DVDDave offline
Re: Python version not available after 12.3 upgrade
Yes, it worked in Indigo 2022.1 but broke when I updated to OS 12.3.1. I also saw that the error was from the Python version check and, as a test, I added Python3 to the list so it would pass the test. (There are no longer Python2 directories in /usr/bin in OS 12.3.) The check passes but the plots don't work since I assume the plugin wants Python2.
The only error I get is:
INDIGOplotD Error               restarting SQL import,    it seems to hang. If this happens several times reload INDIGOplotD :
I'm perpetually confused by python installations and usually make a mess of it. In this case I didn't try to reinstall Python2 since it's my understanding that it's no longer supported in 12.3. I don't know how Indigo temporarily works around the issue but that workaround doesn't seem to work in this case.
--Dave
edit: BTW, I'm looking into the MatPlotlib plugin which may be a good alternative to INDIGOPlotD
Sun May 15, 2022 4:30 pm
I equally ignore python versions as I’m Windows not Mac by trade.
I’ll bow out to any other devs to help.
Sun May 15, 2022 4:34 pm
DVDDave offline
:D
thanks for the help
Sun May 15, 2022 4:51 pm
Our python installs place executable symlinks in /usr/local/bin.
The plugin developer will need to address this issue. Moving it to his forum.
Sun May 15, 2022 8:10 pm
DVDDave offline
Thanks, Jay. Definitely useful info and I edited the plugin to point at that location. Unfortunately the plots still don't update and new ones don't get created. No errors in the log though so it would be really difficult to troubleshoot at this point. I'll give up for now and go back to trying to learn Matplotlib.
Sun May 15, 2022 11:23 pm
I will check when I am back home on Tuesday evening
Sun May 15, 2022 11:26 pm
DVDDave offline
Thanks Karl. I'm glad you're still working on it.
Sun May 15, 2022 11:27 pm
Did you download the latest version?
Mine works fine w indigo 2022
Sun May 15, 2022 11:30 pm
DVDDave offline
Yeah, but the problem is not with Indigo 2022. It started when I upgraded to MacOS 12.3.
Sun May 15, 2022 11:38 pm
You need both
indigo 2022
Latest v of indigoplotd
For 12.3
Mon May 16, 2022 12:02 am
DVDDave offline
I have all of that. When I upgraded to OS 12.3.1, I no longer had Python2 in /usr/bin so it failed the test built into the plugin. Even after I pointed the plugin where Indigo created symbolic links to Python2 in /usr/local/bin, there were no errors in the log but the plots didn't update.
Mon May 16, 2022 12:27 am
There are some libs it needs.
And when you use a private python install not everything is present
Mon May 16, 2022 8:03 am
DVDDave offline
Is there a list available of the libraries that need to be installed?
