iOS shortcuts
Tue Jul 23, 2019 10:41 pm
iOS shortcuts
I am trying to setup several shortcuts that use the same ipnumber. I would like to use a variable to set the ip number once. Then use that variable in all other shortcuts.
I have been trying to do that for a day or so but can’t figure how to do that.
Has anyone done this?.. and how?
Karl.
Wed Jul 24, 2019 10:38 am
berkinet offline
Re: iOS shortcuts
I have been trying to do that for a day or so but can’t figure how to do that....
Via the clipboard, or likely more useful, via a file (like Dropbox or iCloud, etc.)
Wed Jul 24, 2019 11:11 am
Re: iOS shortcuts
looks like iOS shortcuts do NOT have persistent / global variables..
But here is what seems to work:
A)
1. create a contact "ip" with last name = 192.168.x.x
B) in shortcuts:
1. contacts: select specific contact (ip number)
2. ssh: in hosts field select details of contact = last name
.. fill out userid, password and command
then there have several shortcuts with different commands
here the iPhone screen shot
Screen Shot 2019-07-24 at 12.10.43.png (196.58 KiB) Viewed 3766 times
Wed Jul 24, 2019 4:42 pm
Re: iOS shortcuts
more more comment:
it seems that shortcuts do not re-read the input apps, ie when changing the contact info the shortcuts continue to use the old info.
Even deleting the contact does not change the behavior of the shortcuts.
Using file info seems to work fine. When files are deleted , the shortcuts fail, when recreating them they work fine again.
So here the version that seems to be working well...
Screen Shot 2019-07-24 at 17.41.23.png (94.13 KiB) Viewed 3731 times
Although it is a little difficult to create a file in the shortcuts folder - first get a file editor. create the file with contents 192.162.x.x , then use files to move / copy the file into the shortcuts folder.
Wed Jul 24, 2019 7:47 pm
mundmc offline
Re: iOS shortcuts
Intrigued- what you up to here Karl?
Wed Jul 24, 2019 11:03 pm
Re: iOS shortcuts
I have been working on a big project for ~ six months.
Lot of hardware, wood, paint, plastic, cables sensors, step motor, 3watt rgb-led, electronics,display, switches, magnets and about 10k lines of python ...
one month left to go.
Thu Jul 25, 2019 7:38 am
mat offline
Re: iOS shortcuts
its a new door lock, I've seen the trailer :lol:
https://www.youtube.com/watch?v=9AYdLv0g67s
Late 2018 mini 10.14
Fri Jul 26, 2019 8:21 am
durosity offline
Re: iOS shortcuts
Oooh that’s fancy!
Fri Jul 26, 2019 1:14 pm
mundmc offline
Re: iOS shortcuts
Please tell me it’s this!
Fri Jul 26, 2019 2:22 pm
Re: iOS shortcuts
base it is round ~ 15 " in diameter 2.5" high, total weight = 5.0 US pound = 2.3kg
