sd images
Fri Dec 07, 2018 8:59 am
koburg offline
sd images
hi
What is the difference between the 3 images for the PiBeacon?
-Allan
Fri Dec 07, 2018 10:27 am
Re: sd images
which images? on the position plot?
Fri Dec 07, 2018 11:11 am
koburg offline
Re: sd images
sorry my bad
the Sd card images which I transfer to the sd card got an extra rasperry pi 3 b+
Fri Dec 07, 2018 1:35 pm
Re: sd images
The date in the name should be the indicator when it was created.
Just use the last one.
But do not upgrade on your own !!!
The Bluetooth will stop working. It is high on my prio list but I need 2 full days straight to dig into it. Some libs need to be in sync ....
Fri Dec 07, 2018 1:46 pm
Re: sd images
Fri Dec 07, 2018 3:06 pm
koburg offline
Re: sd images
ok great
and it should work with the new pi 3 b+ ?
because seems to be problem loading the burned sd card on the pi
Fri Dec 07, 2018 3:17 pm
koburg offline
Re: sd images
seems to be running now second burning did it
Fri Dec 07, 2018 8:36 pm
Re: sd images
That’s an indication that the ssd might be bad.
Sat Dec 08, 2018 1:40 am
koburg offline
Re: sd images
Hope Not
This is a brand new 16gb from a complete original bundle
Directly from raspberry pi
Sat Dec 08, 2018 4:32 pm
Re: sd images
An update on SSD versions
the 2018-04 version seems to work on ALL rpi
upgrading to the latest 2018-11:
== works on RPI2 ..
== but not on RPI3+ ... don't have a RPI3. - tried in 2 ways: (A) upgrade from 2018-04 and (B) a fresh download of 2018-11 same result.
--- the bluetooth._bluetooth python lib seems to be not working. No data is returned when using it in python - also no error message.
--- the command line tools (eg hcitiool) work fine..
so for the time being continue to use the 2018-04 stretch version.. this might take some time.
Sat Dec 08, 2018 6:06 pm
Re: sd images
SSD for RPI3+
.. adding an external BLE dongle seems to make it work.. something wrong / different with internal NEW rpi3plus BLE 4.1 chip ..
Sun Dec 09, 2018 3:45 am
koburg offline
Re: sd images
ok thanks
it is working with the 2018-4 version at the moment have not upgraded yet wait until you say so.
i have only upgraded to the latest plugin for indigodomo.
Sun Dec 09, 2018 11:14 pm
Re: sd images
just published a new SSD and plugin that work with latest raspberry stretch . (fully upgraded w sudo apt-get upgrade ... on dec 08, 2018)
BUT the RPI3plus has issues. you need to add an extra USB BLE dongle/ stick
otherwise it seems to be working fine.
so if you don't have problems, no need to upgrade your SSD/ opsys image
one nice addition is to be able to delete an RPI completely from indigo, device and internal tables. if you wan to eg reuse or replace an RPi ...
and the RPI will now be created when you define it in initial setup, no need to wait until the first iBeacon message arrives from the RPI
Thu Dec 20, 2018 9:28 am
koburg offline
Re: sd images
ok great I still wait for when you solve the bluetooth.
btw: you where right the sd card died replaced and now is running again.
have you tried a bluetooth 5.0 dongle yet if they exits yet ?
Thu Dec 20, 2018 12:38 pm
sd images
For the rpi3+ you need an extra dongle ~$10 - for the latest ops sys.
rpi3 has a different BLE chip. it has issues running in parallel w wifi. here w wifi you also need an extra BLE dongle, but only for BLEconnect
rpi1 2 3 run on latest opsys wo problem.
Really don’t know what to do.
Ble5 has no advantage as the iBeacon are very simple BLE 4 devices.
