More elegant close down errors
Mon Dec 23, 2019 3:50 pm
Howdy
So whenever the Plex server shuts down these days I start getting loads of errors:
   Mac Apps                        "Server - App: Plex" off
   Plex Media Server Manager Error An error occurred executing the GET/PUT request (Device: 892813893): HTTPSConnectionPool(host='127.0.0.1', port=32400): Max retries exceeded with url: / (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x10d55fcd0>: Failed to establish a new connection: [Errno 61] Connection refused',))
  File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/Plex Media Server Manager.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkRESTfulDevice.py", line 256, in concurrentCommandProcessingThread
    responseObj = requests.get(fullGetUrl, auth=authenticationParam, headers=customHeaders, verify=False)
  File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/api.py", line 71, in get
    return request('get', url, params=params, **kwargs)
  File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/api.py", line 57, in request
    return session.request(method=method, url=url, **kwargs)
  File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/sessions.py", line 477, in request
    resp = self.send(prep, **send_kwargs)
  File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/sessions.py", line 587, in send
    r = adapter.send(request, **kwargs)
  File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/adapters.py", line 481, in send
    raise ConnectionError(e, request=request)
ConnectionError: HTTPSConnectionPool(host='127.0.0.1', port=32400): Max retries exceeded with url: / (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x10d55fcd0>: Failed to establish a new connection: [Errno 61] Connection refused',))
   Plex Media Server Manager Error An error occurred executing the GET/PUT request (Device: 892813893): HTTPSConnectionPool(host='127.0.0.1', port=32400): Max retries exceeded with url: /status/sessions (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x10d55f690>: Failed to establish a new connection: [Errno 61] Connection refused',))
ConnectionError: HTTPSConnectionPool(host='127.0.0.1', port=32400): Max retries exceeded with url: /status/sessions (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x10d55f690>: Failed to establish a new connection: [Errno 61] Connection refused',))
   Plex Media Server Manager Error An error occurred executing the GET/PUT request (Device: 892813893): HTTPSConnectionPool(host='127.0.0.1', port=32400): Max retries exceeded with url: /clients (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x10d55f750>: Failed to establish a new connection: [Errno 61] Connection refused',))
ConnectionError: HTTPSConnectionPool(host='127.0.0.1', port=32400): Max retries exceeded with url: /clients (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x10d55f750>: Failed to establish a new connection: [Errno 61] Connection refused',))
23 Dec 2019 at 21:42:59
   Plex Media Server Manager Error An error occurred executing the GET/PUT request (Device: 892813893): HTTPSConnectionPool(host='127.0.0.1', port=32400): Max retries exceeded with url: / (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x10d55fa50>: Failed to establish a new connection: [Errno 61] Connection refused',))
ConnectionError: HTTPSConnectionPool(host='127.0.0.1', port=32400): Max retries exceeded with url: / (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x10d55fa50>: Failed to establish a new connection: [Errno 61] Connection refused',))
   Plex Media Server Manager Error An error occurred executing the GET/PUT request (Device: 892813893): HTTPSConnectionPool(host='127.0.0.1', port=32400): Max retries exceeded with url: /status/sessions (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x10d55f410>: Failed to establish a new connection: [Errno 61] Connection refused',))
ConnectionError: HTTPSConnectionPool(host='127.0.0.1', port=32400): Max retries exceeded with url: /status/sessions (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x10d55f410>: Failed to establish a new connection: [Errno 61] Connection refused',))
   Plex Media Server Manager Error An error occurred executing the GET/PUT request (Device: 892813893): HTTPSConnectionPool(host='127.0.0.1', port=32400): Max retries exceeded with url: /clients (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x10d458790>: Failed to establish a new connection: [Errno 61] Connection refused',))
ConnectionError: HTTPSConnectionPool(host='127.0.0.1', port=32400): Max retries exceeded with url: /clients (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x10d458790>: Failed to establish a new connection: [Errno 61] Connection refused',))
   Disabling plugin "Plex Media Server Manager 2.3.5"
   Stopping plugin "Plex Media Server Manager 2.3.5" (pid 672)
   Stopped plugin "Plex Media Server Manager 2.3.5"
Which then just repeats over and over and over again every time it polls the server status. Would it be possible for it to just display a message like "Plex server became unavailable" and something similar when it re-opens?
Tue Dec 24, 2019 3:21 pm
RogueProeliator offline
Re: More elegant close down errors
Is that happening with debug turned off? If so it is a bug -- it certainly should only be pumping that detail out only when the debugging is enabled. I'll add it to take a look as it isn't supposed to look nasty like that.
Tue Dec 24, 2019 8:56 pm
Yep just confirmed debug mode is off:
