Mac System Disk Volume (solved)
Sun Apr 26, 2015 1:18 pm
ELWOOD offline
Bip
No more problems with the application device. Now I started adding devices to control my external hard drives. Added first drive and I am able to
turn it on and off. Attempted to add a second drive with no luck. After adding drive I get the following errors that keep repeating until I delete the device:
__________________________________________
Apr 26, 2015, 2:55:50 PM
Schedule PLOT META OFFICE MOTION (delayed action)
Meta Device META OFFICE MOTIONS Device "META OFFICE MOTIONS" off
Trigger office motion
Trigger PLOT META OFFICE MOTION
AD2USB Alarm Interface Zone: 090 - -Wireless Motion OFFICE z090 state changed to: (Faulted)
Meta Device META OFFICE MOTIONS Device "META OFFICE MOTIONS" on
Sent INSTEON "Office" on to 100
SQL Logger creating table device_history_1848532168 for "new device"
Apr 26, 2015, 2:56:28 PM
Mac System Error shell script failed because /bin/sh: -c: line 0: unexpected EOF while looking for matching `''
/bin/sh: -c: line 1: syntax error: unexpected end of file
Mac System Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 218, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Mac System.indigoPlugin/Contents/Server Plugin/interface.py", line 144, in getVolumeData
<type 'exceptions.TypeError'>: 'NoneType' object is unsubscriptable
Mac System Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Tried on more than one drive with the same results.
The first drive that is still working is connected by USB port, the other drives with errors are connected by firewire.
Elwood
Mon Apr 27, 2015 3:46 am
bip.philippe offline
Re: Mac System Disk Volume
Can you retry with the latest version of plugin configured to logging level 4 and post me the detailed log ?
Sincerely,
Mon Apr 27, 2015 9:11 am
ELWOOD offline
Bip
Log with level 4
___________________
Apr 27, 2015, 11:03:35 AM
Mac System Debug end of validating Prefs
Mac System Debug returned from shell: {'VolumeDevice': u'disk5s2', 'VolumeSize': u'2.0 TB', 'VolumeType': u'Apple_HFS'}
Mac System Debug going to call shell /bin/df | grep 'disk5s2'
Mac System Debug returned from shell: {'Available': u'3904626160', 'Used': u'1665472'}
Mac System Debug Input Keys: Values : {'pcUsed': 0L, 'VolumeSize': u'2.0 TB', 'onOffState': True, 'VolumeType': u'Apple_HFS', 'VolumeDevice': u'disk5s2', 'VStatus': 'on'}
Mac System Debug Updated Keys: Values : {}
Mac System Debug going to call shell ps -awxc -opid,state,comm | grep ' XBMC$'
Mac System Debug time ellapsed for dialog timer "Next disk spin"
Mac System Debug returned from shell: {'ProcessID': '', 'PStatus': ''}
Mac System Debug Input Keys: Values : {'ProcessID': 0, 'onOffState': False, 'PStatus': 'off'}
Mac System Debug going to sleep for 9.2 seconds
Mac System Debug time ellapsed for dialog timer "Read volume data"
Mac System Debug time ellapsed for dialog timer "Read application data"
Mac System Debug going to call shell ls -1 /Volumes | grep '^KODI 4$'
Mac System Debug returned from shell: KODI 4
Mac System Debug Input Keys: Values : {'VStatus': 'on', 'onOffState': True}
Mac System Debug going to sleep for 9.79 seconds
AD2USB Alarm Interface Zone: 090 - -Wireless Motion OFFICE z090 state changed to: (Clear)
AD2USB Alarm Interface Zone: -Wireless Motion Kitchen supervision received. (RFX:0523842,04)
Group Trigger Error Error in plugin execution ServerReplacedElem:
File "plugin.py", line 290, in deviceUpdated
<type 'exceptions.KeyError'>: key onOffState not found in dict
SQL Logger creating table device_history_1606155438 for "new device"
Mac System Debug going to call shell ps -wxc -olstart,pcpu,pmem,etime -p0 | sed 1d
Mac System Debug returned from shell: {'PCpu': '', 'ETime': '', 'LStart': '', 'PMem': ''}
Mac System Debug Input Keys: Values : {'ProcessID': 0, 'PCpu': 0, 'onOffState': False, 'ETime': 0, 'PStatus': 'off', 'LStart': '', 'PMem': 0}
Mac System Debug going to sleep for 9.68 seconds
Mac System Debug validating Device Config called for: (1606155438 - bip.ms.volume)
Mac System Debug end of validating Device Config
Mac System Debug deviceStartComm called for: MINI'S VIDEO 4 (1606155438 - bip.ms.volume)
Mac System Debug end of deviceStartComm
Mac System Debug going to call shell ls -1 /Volumes | grep '^MINI'S VIDEO 4$'
Mac System Debug Input Keys: Values : {'onOffState': False}
Mac System Debug going to call shell pmset -g | grep disksleep | sed -e s/[a-z]//g | sed -e 's/ //g'
Mac System Debug returned from shell: 10
Mac System Debug Input Plugin Property Keys: Values : {'disksleepTime': 10}
Mac System Debug going to call shell /usr/sbin/diskutil list | grep ' KODI 4 '
Mac System Debug going to call shell /usr/sbin/diskutil list | grep ' MINI'S VIDEO 4 '
AD2USB Alarm Interface Zone: -DECK MOTION supervision received. (RFX:0597636,24)
Mac System Debug runConcurrentThread initiated
Mac System Debug initiating dialog timer "Next disk spin" on a 540 seconds pace
Mac System Debug initiating dialog timer "Read volume data" on a 60 seconds pace
Mac System Debug initiating dialog timer "Read application data" on a 60 seconds pace
Elwood
Tue Apr 28, 2015 10:15 am
Elwood
Hi Elwood,
The bug is due to quote in MINI'S VIDEO 4 name.
I have recreated the issue on my test computer by inserting a quote in a volume name.
I am going to issue a corrected plug-in tomorrow.
Sincerely,
Wed Apr 29, 2015 7:31 am
Hi Elwood,
The latest release v1.2.2 should correct the issue.
Let me know,
Sincerely,
Wed Apr 29, 2015 1:56 pm
ELWOOD offline
Bip
1.2.2 up and running with no errors.
Thanks again for the plugin.
Elwood
