[Mac System] 'Send Status Request' error (solved)
Tue Apr 21, 2015 6:45 am
Just trying out your new plugin to monitor how full my ramdisk is - this will be very useful to me - thanks a lot for sharing the plugin :D
Not a major problem, but if you press the Send Status Request button in the Home Window, the following error occurs:
Starting plugin "Mac System 1.1.0" (pid 92259)
Started plugin "Mac System 1.1.0"
Mac System Debug startup called
Mac System Debug end of startup
Mac System Debug deviceStartComm called for: new device (600837587 - bip.ms.volume)
Mac System Debug end of deviceStartComm
Mac System Debug runConcurrentThread initiated
Mac System Debug initiating dialog timer "Next disk spin" on a 540 seconds pace
Mac System Debug time ellapsed for dialog timer "Next disk spin"
Mac System Debug initiating dialog timer "Read volume data" on a 60 seconds pace
Mac System Debug time ellapsed for dialog timer "Read volume data"
Mac System Debug initiating dialog timer "Read application data" on a 60 seconds pace
Mac System Debug time ellapsed for dialog timer "Read application data"
Mac System Debug going to call shell pmset -g | grep disksleep | sed -e s/[a-z]//g | sed -e 's/ //g'
Mac System Debug returned from shell: 10
Mac System Debug Input Plugin Property Keys: Values : {'disksleepTime': 10}
Mac System Debug going to call shell ls -1 /Volumes | grep '^RAMDISK$'
Mac System Debug returned from shell: RAMDISK
Mac System Debug Input Keys: Values : {'VStatus': 'on', 'onOffState': True}
Mac System Debug Updated Keys: Values : {}
Mac System Debug going to call shell /usr/sbin/diskutil list | grep ' RAMDISK '
Mac System Debug returned from shell: {'VolumeDevice': u'disk4', 'VolumeSize': u'536.9 MB', 'VolumeType': u''}
Mac System Debug going to call shell /bin/df | grep 'disk4'
Mac System Debug returned from shell: {'Available': u'223208', 'Used': u'825368'}
Mac System Debug Input Keys: Values : {'pcUsed': 78, 'VolumeSize': u'536.9 MB', 'onOffState': True, 'VolumeType': u'', 'VolumeDevice': u'disk4', 'VStatus': 'on'}
Mac System Debug going to sleep for 9.4 seconds
Mac System Error Error in plugin execution ExecuteAction:
File "plugin.py", line 203, in actionControlDimmerRelay
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Mac System.indigoPlugin/Contents/Server Plugin/bipIndigoFramework/relaydimmer.py", line 53, in startAction
<type 'exceptions.KeyError'>: (indigo.kDimmerRelayAction(11),)
Mac System Debug going to sleep for 9.88 seconds
Tue Apr 21, 2015 8:56 am
bip.philippe offline
Re: [Mac System] 'Send Status Request' error
I see where is the issue.
I am going to correct this in the following days.
Sincerely,
Wed Apr 22, 2015 8:54 am
v1.1.1 should correct this bug.
Let me know,
Wed Apr 22, 2015 9:45 am
Well done - Yes, it's fixed - Thanks :D
