Bike Share Plugin - Updates
Thu Feb 26, 2015 8:19 pm
The Bike Share Plugin has been updated.
v0.1.1
- Better honors device start comm/stop comm.
- Updates plugin with support URLs.
- Code refinements.
Fri Jul 31, 2015 5:10 am
Re: Bike Share Plugin - Updates
v0.1.2
- Fixes duplicate state label.
- Increases compliance with PEP8.
Wed Apr 06, 2016 8:12 pm
v0.1.3
- Adds two new states: "isRenting" and "Renting".
- Minimizes outreach to the sharing servers.
- Ensures that devices are not restarted unnecessarily.
- Implements setErrorStateOnServer() method.
- Implements error screens in config dialog.
- Further PEP8 refinements.
- Updates plugin to use Python 2.6 as default.
- Changes url for update checker to use https.
- Simplifies imports.
- UI Refinements.
Sun Dec 18, 2016 2:32 pm
v1.0.01
- Updates version number to full release and moves the project to GitHub.
Download the latest version from GitHub.
Mon Mar 06, 2017 8:52 am
Version v1.0.02 of the Bikeshare plugin is now available.
  • Adds trigger to report when a station is not in service.
  • Add menu item to enable/disable all plugin devices.
  • Adds Indigo UI icon indicator control: (green = online, gray = offline/disabled/out of service, red = error/no comm)
  • Moves support URL to Github.
  • UI Refinements
Download the latest version here.
Mon Aug 21, 2017 4:01 pm
Version v1.0.03 of the Bikeshare plugin is now available.
  • Stylistic changes to Indigo Plugin Update Checker module.
  • Improved exception logging.
  • Code simplification.
  • Adds remote debugging capability.
  • Moves updater config to template.
You may ignore this update if the plugin is working well for you.
Thu Sep 07, 2017 5:59 am
Version v1.0.04 of the Bikeshare plugin is now available.
  • Standardizes plugin menu item styles. Menu items with an ellipsis (...) denote that a dialog box will open. Menu items without an ellipsis denote that the plugin will take immediate action.
  • Fixed bug related to version control for "Check for Plugin Updates" menu action.
Sun Oct 22, 2017 7:24 am
Version v1.0.05 of the Bikeshare plugin is now available.
  • Under-the-hood code refinements.
  • Adds note to documentation that the plugin requires Internet access in order to function.
This update does not add any new functionality to the plugin.
Mon Feb 05, 2018 7:21 am
Version v1.0.07 of the Bikeshare plugin is now available.
  • Updates help link to wiki.
  • Updates plugin update checker to use curl to overcome outdated security of Apple's Python install.
Thu May 10, 2018 4:12 pm
Version v1.1.01 of the Bikeshare plugin is now available.
Note: Indigo 7 is now required to use the plugin.
  • Updates to Indigo API 2.0.
  • Converts testStation device state from string to boolean True/False.
  • Refactors 'dataAge' and 'executionTime' device states:
    • 'dataAge' now keyed to the last time the bike dock station communicated with the bike sharing service.
    • 'executionTime' now keyed to the last time the Indigo plugin communicated with the bike sharing service.
  • Removes legacy device state 'renting'. Users should use the state 'isRenting'.
View the plugin documentation here.
Tue Jul 31, 2018 6:36 am
Version v1.1.02 of the Bikeshare plugin is now available.
  • Fixes bug in plugin menu item to check for latest version.
Mon Dec 31, 2018 10:22 am
Version v1.1.03 of the Bikeshare plugin is now available.
  • Adds Write Data to File option to plugin menu.
  • Removes plugin update notifications.
  • Code refinements.
Sun Oct 13, 2019 6:32 am
Version v2.0.03 of the Bikeshare plugin is now available.
  • Adds business hours feature.
  • Complete rewrite of the plugin to use the standardized GBFS (General Bikeshare Feed Specification) data sharing specification.
This plugin update moves to the GBFS (General Bikeshare Feed Specification) standard. This allows the plugin to offer over 250 sharing systems worldwide (257 as of the time of this release). WARNING: This update is not backward compatible with prior releases of the plugin. It uses an entirely new data structure that does not support prior plugin devices.
