Bike Share Plugin - Updates
Thu Feb 26, 2015 8:19 pm
The Bike Share Plugin has been updated.
v0.1.1
- Better honors device start comm/stop comm.
- Updates plugin with support URLs.
- Code refinements.
Fri Jul 31, 2015 5:10 am
Re: Bike Share Plugin - Updates
v0.1.2
- Fixes duplicate state label.
- Increases compliance with PEP8.
Wed Apr 06, 2016 8:12 pm
v0.1.3
- Adds two new states: "isRenting" and "Renting".
- Minimizes outreach to the sharing servers.
- Ensures that devices are not restarted unnecessarily.
- Implements setErrorStateOnServer() method.
- Implements error screens in config dialog.
- Further PEP8 refinements.
- Updates plugin to use Python 2.6 as default.
- Changes url for update checker to use https.
- Simplifies imports.
- UI Refinements.
Sun Dec 18, 2016 2:32 pm
v1.0.01
- Updates version number to full release and moves the project to GitHub.
Download the latest version from GitHub.
Mon Mar 06, 2017 8:52 am
Version v1.0.02 of the Bikeshare plugin is now available.
  • Adds trigger to report when a station is not in service.
  • Add menu item to enable/disable all plugin devices.
  • Adds Indigo UI icon indicator control: (green = online, gray = offline/disabled/out of service, red = error/no comm)
  • Moves support URL to Github.
  • UI Refinements
Download the latest version here.
Mon Aug 21, 2017 4:01 pm
Version v1.0.03 of the Bikeshare plugin is now available.
  • Stylistic changes to Indigo Plugin Update Checker module.
  • Improved exception logging.
  • Code simplification.
  • Adds remote debugging capability.
  • Moves updater config to template.
You may ignore this update if the plugin is working well for you.
Thu Sep 07, 2017 5:59 am
Version v1.0.04 of the Bikeshare plugin is now available.
  • Standardizes plugin menu item styles. Menu items with an ellipsis (...) denote that a dialog box will open. Menu items without an ellipsis denote that the plugin will take immediate action.
  • Fixed bug related to version control for "Check for Plugin Updates" menu action.
Sun Oct 22, 2017 7:24 am
Version v1.0.05 of the Bikeshare plugin is now available.
  • Under-the-hood code refinements.
  • Adds note to documentation that the plugin requires Internet access in order to function.
This update does not add any new functionality to the plugin.
Mon Feb 05, 2018 7:21 am
Version v1.0.07 of the Bikeshare plugin is now available.
  • Updates help link to wiki.
  • Updates plugin update checker to use curl to overcome outdated security of Apple's Python install.
Thu May 10, 2018 4:12 pm
Version v1.1.01 of the Bikeshare plugin is now available.
Note: Indigo 7 is now required to use the plugin.
  • Updates to Indigo API 2.0.
  • Converts testStation device state from string to boolean True/False.
  • Refactors 'dataAge' and 'executionTime' device states:
    • 'dataAge' now keyed to the last time the bike dock station communicated with the bike sharing service.
    • 'executionTime' now keyed to the last time the Indigo plugin communicated with the bike sharing service.
  • Removes legacy device state 'renting'. Users should use the state 'isRenting'.
View the plugin documentation here.
Tue Jul 31, 2018 6:36 am
Version v1.1.02 of the Bikeshare plugin is now available.
  • Fixes bug in plugin menu item to check for latest version.
Mon Dec 31, 2018 10:22 am
Version v1.1.03 of the Bikeshare plugin is now available.
  • Adds Write Data to File option to plugin menu.
  • Removes plugin update notifications.
  • Code refinements.
