Page 2 of 2
Re: APC Power Distribution Unit (PDU) Plugin Added
PostPosted: Fri Jan 19, 2018 8:53 pm
by lanbrown
Swancoat wrote:
2. Could you support a 'reboot' action? Some equipment I can handle with an on/off, but sometimes I want to reboot a router or switch, and of course as soon as I shut it off, I can't connect to turn it on. The reboot action would handle this well.
Could you create a trigger using this plugin? If you can, in the trigger it would turn the port off but you would select the option under actions to be auto-on after so many seconds, minutes or hours.
PostPosted: Sat Jan 20, 2018 9:10 pm
by Swancoat
Yeah, but the ON command still wouldn’t get to the PDU because the router or switch is off. The PDU connects via IP. The PDU has the ability to execute a ‘reboot’ which is an OFF followed by an ON after a pre-determined time with all of that time logic being handled by the PDU, so it will still happen, even if it loses communications.
