Error in plugin execution UiGetValues1
Fri Dec 22, 2017 3:49 am
Coolcaper offline
I have been using the old Autolog Smappee plugin and all was fine till a couple of days ago, there was no info being gathered. So I switched to the new Smappee plugin. However I am getting this error when I try to create a Smappee device:
Smappee Error Error in plugin execution UiGetValues1:
TypeError: No registered converter was able to extract a C++ reference to type CXmlDict from this Python object of type list
Error (client) _sendClosedConfigUi3() caught exception: LowLevelBadParameterError
Smappee Error Error in plugin execution UiClosed3:
File "plugin.py", line 946, in closedDeviceFactoryUi
KeyError: (u'NONE',)
Fri Dec 22, 2017 9:55 am
Re: Error in plugin execution UiGetValues1
Just taken a look at this and can't quite see how to resolve it without getting more info. :|
I suspect that the Location might not be set? When you edit the devices is there a location value shown. Are there any other messages in the log?
Maybe you could reload the plugin and paste back what the event log shows.
if that doesn't shed any light on the situation, I might need to see a full debug log.
I have the version form the Indigo Plugin Store running on my system OK. Just need to work out what is causing this issue, which obviously the plugin should handle. :)
You mentioned that all of a sudden a few days ago it stopped working. Can you log onto the Smappee monitor and are you getting updates through on the iOS Smappee App?
Fri Dec 22, 2017 7:36 pm
Coolcaper offline
Hi Jon,
Managed to get around this by completely deleting the plugin and pref files and reinstalling.
It's working fine now. Thanks and merry Christmas!
