Disable Startup
Posted:
Thu Mar 11, 2021 4:07 am
by petematheson
Hi All,
I'm switching Indigo between Mac's - How can I stop Indigo from loading on the old mac?
It's not listed in startup items, yet every time I boot it loads up in the background and only stops when I manually load up Indigo and stop the server.
Re: Disable Startup
Posted:
Thu Mar 11, 2021 6:59 am
by autolog
How I would do it is:
- Start Indigo on old Mac
- From main Indigo menu, click first menu item (to left of File = Indigo 7.5?), click menu item Stop Server
- From the Server Connection Status dialogue, click Start Local Server
- From the Start Local Server dialogue, uncheck Auto start Indigo Server on user login
- Click Start Server
- Then close down Indigo i.e. Stop Server and quit Indigo
After that it shouldn't start.
Re: Disable Startup
Posted:
Thu Mar 11, 2021 8:26 am
by petematheson
Ahhhh THAT'S where the option is. haha! Thanks
Re: Disable Startup
Posted:
Tue Aug 10, 2021 6:02 pm
by joekewe
I installed a temporary server to work on an airplane without an internet connection. After returning home, Indigo 7.4 tries to launch the server every time I restart. I tried turning off "auto-start," but I can't "start" the server to make the setting stick because I keep getting the attached dialog. How can I permanently tell Indigo to stop launching the server (which crashes in the background) every time I restart?
Joe
Re: Disable Startup
Posted:
Wed Aug 11, 2021 6:44 pm
by matt (support)
Choosing the Indigo->Connect to Remote Server... should just have the client connect to a different Mac and not try to start the Indigo Server.
You can also just delete the Indigo Server.app from /Library/Application Support/Perceptive Automation/Indigo 7.4/.
