I've been using Indigo for a while with a mixture of Z-wave and Insteon devices. I'm now in the process of replacing ALL my wall switches with Insteon ones.
My question is this. What is the best way to create a multi-way switch? I have 2 Insteon devices, with one connected to a load (light). Should I simply create an Insteon Group, or is there a better way to have both switches control the 1 load? What about for dimmer? Again, 2 Insteon dimmers, 1 dimmable load. How to create 3-way scenario where either dimmer can cause the load to dim and the other dimmer instantly reflects the level of the active one.
Thank you in advance,
J.
