Hello,
I am new to Indigo and new to Mac. I have a Mac Mini.
I have installed the Indigo trial, added a Z-Stick, and a GE outlet plug-in on/off appliance module.
Everything went smoothly. Within Indigo I am able to turn the outlet on or off manually. I set up a schedule to turn it on at a time approximately an hour from the current time.
I came back a few minutes after it should've turned on and I saw the Mac Mini was asleep. The USB ports on the mini were powered off, and the Z-Stick was powered off. The appliance module had not turned on.
After waking up the Mac, I tried to cycle the appliance module from Indigo manually – seemed not to be found. I tried to re-sync the appliance module and Indigo reported a timeout communicating.
I walked over to the appliance module and pushed the button. I guess it then woke up or something and I was able to manually control the appliance module from Indigo.
What actually happened here?
I'm going to take a wild guess – the Mac went to sleep, the Z-Stick turned off, the appliance module realized the Z-wave controller was missing so it went to sleep, Indigo lost communication???
Must I have the Mac Mini set to never sleep? Would an external powered hub make the Z-Stick not be powered down if the Mac sleeps? Is this the preferred way to go.
I come from a Windows world so I'm not familiar with the Mac at all.
Will Indigo function if the Mac goes to sleep?
Will a powered hub keep the Z-Stick alive and devices in the Z-wave network recognized?
Barry.
