Hello,
I'm looking to switch from SmartThings to Indigo.
My automation is really pretty simple – three motion detectors, a few sets of lights, an Aeotec doorbell, and a ZSmoke smoke detector.
But here's the biggie. I have bulbs located all around the house screwed into adapters that plug directly into wall outlets. When the doorbell rings, the bulbs flash for 10 seconds. I also plan, in the future, to have a bulb flash, and bed shaker activate when the smoke detector goes off.
I don't see the "Things" listed in the officially supported devices to accommodate this. I've seen in the FAQ that more Z-wave devices are compatible than are listed.
For motion detectors, the EcoLink is readily available. I have seen mention in these forums that somebody successfully uses it.
Is the ZSmoke compatible (not the ZCombo). I have this connected to SmartThings as a Z-Wave device.
How can I control bulbs? I have one group of bulbs that can be controlled by an appliance module. I have a second group of bulbs, which are inside a fixture, that will not work with a wall switch, outlet module, or light socket Z-Wave adapter. In SmartThings these bulbs are controlled as Zigbee devices. The bulbs are a mix of GE Link, Cree, and WeMo.
Finally, most important, are the bulbs which I have blinking. I use these as alerters. I need to be able to locate these blinker bulbs all over the house, they need to be obvious, they really can't be in a fixture, and they can't be too obtrusive (as in a wall plug outlet for each bulb).
Any suggestions how I could achieve this?
I am drawn to Indigo for the reliability and robustness.
Barry.
