the shortest version i can give you of my problem, hopefully someone has some advice.
problem 1... the only way i can remotely access anything in my house is thru the goprism reflector service offered thru indigo. This is due to the fact that my internet is rural cellular lte and doesn't have a static ip (can't get 1) and blocks ddns with dual private ip's. I won't ever be able to fix this, have tried, and it's just not happening.
problem 2... I have ip cameras, they record locally in HD, however I need security spy to pick up a refreshing image url in order for the goprism service to be able to see my cameras from outside the house on a indigo control page.
problem 3... i can't create a refreshing image from my cams without security spy.
problem 4... this is the big problem. I'm Canadian, and with the value of our dollar right now i can't justify 80$ per camera just to look at the refreshing image url. I'll never use security spy for anything else. when I'm at home i can see my cams fine with the native Insteon app, i use the built in recording features etc.
so in a nutshell, the real problem is 80$ a camera (I have 4) just for a refreshing image about 300 x 180 pixels.
please, i need a suggestion
