So I was going to order the Aeon Labs Aeotec USB adaptor, but is is sold out eveywhere.
Does anyone know if the z-wave UZB can be used with Indigo?
http://z-wave.me/index.php?id=28
thank you
-Ray
2015-09-02 15:53:16.940 Z-Wave connected to Z-Wave 3.99 static controller interface on /dev/cu.usbmodemfa131 (firmw
are 5.01)
2015-09-02 15:53:16.940 Z-Wave Debug SENT getInitialNodeData: 01 03 00 02 FE
2015-09-02 15:53:16.940 Z-Wave Debug RCVD getInitialNodeData: 01 0C 00 0A 05 00 01 02 01 03 FF FF FF 02 (unsolici
ted2 -- requeuing)
2015-09-02 15:53:17.066 Z-Wave Debug RCVD getInitialNodeData: 01 25 01 02 05 08 1D 07 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 CB
2015-09-02 15:53:17.066 Z-Wave Debug . . getInitialNodeData: is static update controller
2015-09-02 15:53:17.066 Z-Wave Debug . . getInitialNodeData: [1, 2, 3]
2015-09-02 15:53:17.067 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 01 BB
2015-09-02 15:53:17.067 Z-Wave Debug RCVD getNodeProtocolInfo: 01 0C 00 0A 05 00 01 02 01 03 FF FF FF 02 (unsolic
ited2 -- requeuing)
2015-09-02 15:53:17.069 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 93 16 01 02 02 01 33
2015-09-02 15:53:17.070 Z-Wave Debug . . getNodeProtocolInfo: node 001, class name: Static Computer Contro
ller
2015-09-02 15:53:17.070 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Static Controller : St
atic Controller : Static Computer Controller (02 : 02 : 01)
2015-09-02 15:53:17.070 Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
2015-09-02 15:53:17.070 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20
2015-09-02 15:53:17.070 Z-Wave Debug . . getNodeProtocolInfo: features: beaming
2015-09-02 15:53:17.070 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 02 B8
2015-09-02 15:53:17.070 Z-Wave Debug RCVD getNodeProtocolInfo: 01 0C 00 0A 05 00 01 02 01 03 FF FF FF 02 (unsolic
ited2 -- requeuing)
2015-09-02 15:53:17.072 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D2 94 00 03 10 01 E2
2015-09-02 15:53:17.073 Z-Wave Debug . . getNodeProtocolInfo: node 002, class name: Relay Power Switch
2015-09-02 15:53:17.073 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Slave : Relay Switch :
Relay Power Switch (03 : 10 : 01)
