I originally had a Brinks system installed 10 years ago so all of the motion sensors and contacts are whatever Brinks installed. I then moved to a Sequel ST8 (no longer in business) and did this myself. I was able to get everything to work. However, without this company in business I need to switch to something else. I had a DSC 1832 with IT100 (serial interface) and 2 keypads laying around brand new. So I just installed this and I get the trouble light and error code 3 (general trouble).
The system has 6 zones, 2 keypads, 1 siren and 1 Serial interface:
Zone 1: Front Door has two wires (black and red). I wired Red to Zone 1 and black to Common
Zone 2: Door through garage and has two wires( black and red). I wired Red to Zone 2 and black to Common
Zone 3 & 4: These are doors and was referred to as a 'flex kit' on my install diagram (I believe glass break and door sensor). This has 4 wires. I put black/red on auxiliary inputs and then green on common and white on zone 3. (note this was consistent with how they were setup and working on the previous system.
Zone 5/6: All motion detectors wired the same as Zone 3 (black/red on auxiliary inputs) and green on common and white on the Zones.
Resistors: I put a single zone resistor on Zone 7 and Common and I put a resistor on Zone 8 and Common.
Any ideas what is going on here? I just get the flashing yellow light with error code 3. I also see an icon that looks like a door is open. I have enabled chimes but nothing works.
