[ANSWERED]: Help with FortrezZ water / temp sensor
Posted: Tue May 19, 2015 11:12 am
I hav 10 FortrezZ sensors model number WWA-01AA installed. They are all included in the network and properly trip the alarm if a leak is detected.
The manual indicates that they should also report temperature too. None of them do this. In the Indigo device list, they all show 22 C, regardless of the actually temp. I put one in the freezer and I put one in a 50 degree garage. they still say 22 C in the list.
I set the wake up time to 30 minutes. nope.
I looked through the log file and noticed that there has never been a temperature report from any of the sensors. I know there is an option to hide temperature reports from the log, this is NOT set.
On the FortrezZ support site, there is an FAQ where the question was asked about this model of sensor reporting temperature and the answer was
Does something need to happen on the Indigo side to enable this?
Here is a profile of the sensor:
Indigo Z-Wave Version: 1.0.350
Node ID: 14
Model: Water/Temperature Sensor (WWA01AA)
Model ID: 00530216
Manufacturer: FortrezZ
Manufacturer ID: 0084
Protocol Version: 2.48
Application Version: 2.22
Model Definition Version: 4
Library Type: 6
Class Name: Binary Sensor (routing)
Class Hierarchy: 04 : 20 : 01
Command Class Base: 30
Command Versions: 20v1 80v1 84v2 85v1 86v1 30v1 31v1 72v1 9Cv1 9Dv1
Features: routing, battery, beaming, waking
Neighbors: - none -
Associations: 1:[1] 2:[]
Config Values: - none -
Yes, but only if the controller is set up to request the updated temperature reading when it receives the 'wakeup notification' from the WWA01 / WWA01AA. In order to use the WWA01 / WWA01AA for reporting temperatures that change often, a short wakeup interval time is necessary (with the attendant reduction in battery life).
Node ID: 14
Model ID: 00530216
Library Type: 6
Neighbors: - none -
