- Posted on
Mon Jun 27, 2016 2:58 pm
Mattias
offline
I'm not sure if I turned on the correct debugging (configure zwave, show debugging in event log)
Turning 018 on/off didn't do anything to the log, but I got the below (with 018 in the middle) when turning on the log (along with tons of more)
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 10 01 ED
Z-Wave Debug . . getNodeProtocolInfo: node 018, class name: Relay Power Switch
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 25
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 25 27
Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
Z-Wave Error device "018 - Ute Vxthus" module endpoint type lookup failed
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 2A 90
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 01 17 3F 01 47 02 DB
Z-Wave Debug . . getNodeProtocolInfo: node 042, class name: Controller
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Controller : -- : -- (01 : 47 : 02)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
Z-Wave Debug . . getNodeProtocolInfo: features: beaming, secs
Can you see anything obvious?
