Best motorized blinds / shades with Indigo integration
Tue Nov 26, 2019 11:18 pm
Korey offline
So.. I am getting the request to install automated blinds from my Wife! :D
I have scoured the forums and know there are many different options.
I was hoping to do full wireless with perhaps a solar panel on the window side if the blind to keep the battery charged, running power and signal to the Locations would be a PITA.
Looks like $omfy with the RTS to Zwave control would be an option, as well as Perrys Lutron plugin, I already have an RFXCOM TX unit so Rollertroll are an option as well.
Ideally there would be to have a manual wall control switch as well for ease of use and don the road when we sell.
Looking for comments / suggestions from fellow Indigoers who may have gone down this road. Any advice / recommendations is greatly appreciated. looking at automating at least 6 windows.
Korey
Wed Nov 27, 2019 1:46 am
Re: Best motorized blinds / shades with Indigo integration
I’ve an unpublished Somfy MyLink plugin written; I believe the up/down/stop/‘My’ features work, but I wrote it for someone else.
Happy to update if necessary.
Wed Nov 27, 2019 7:10 am
jalves offline
I'm using Somfy Z-wave shades on 4 different windows in my home. No need for a bridge, but getting them properly set up in Indigo was a bit dodgy. They work fine with Indigo or with the included manual control.
Jeff
Sat Nov 30, 2019 1:54 pm
freshwuzhere offline
I’ve been using rfxcom with standard Somfy RTS and rollertrol - about 4 blinds and an external awning. If you have the rfxcom - the wall penetrating power of that unit is a big differentiator. If your shades are inside and well covered by Z-wave - probably not a big deal.
Set up of rollertrol is a little more complex on rfxcom.
Sat Nov 30, 2019 3:37 pm
Honestly, Lutron shades are head and shoulders above Somfy, IMO. The Lutron controls are rock solid, and the shades themselves are an order of magnitude quieter than anything else I've ever looked at.
But you pay for it.
Wed Dec 04, 2019 2:49 pm
Korey offline
But you pay for it.
Are you using Perrys plugin to control from indigo?
Edit, I guess not as I just searched and noticed your plugin :oops:
What should I be requesting on the quote from Lutron to interface to Indigo?
Korey
Wed Dec 04, 2019 2:56 pm
Korey wrote:
But you pay for it.
I'm using the Lutron plugin (which I'm maintaining).
Wed Dec 11, 2019 11:18 am
brettlid offline
I got Bali cellular motorized shades which have z-wav built in. Work great and we're easy to integrate into Indigo. If you got a Costco membership you can order them online through Costco.
Wed Dec 11, 2019 11:21 am
Depends on what you're using to control the shades in the first place. If just local control with Pico remotes, a Caseta Smart Bridge will do the job.
Mon Dec 16, 2019 1:36 pm
7rdr7 offline
I'm using Hunter Douglas Powerview blinds, with the Indigo Powerview plugin and it works well.
Sat Apr 18, 2020 6:58 pm
benish offline
I'm researching this same thing, but for my office I need blinds (not shades). I've been scouring the internet but I can't find a clear answer as to if the Lutron Smart Bridge Pro can control Lutron blinds.
These pages just mentions shades:
https://www.casetawireless.com/works-wi ... desandfans
https://www.casetawireless.com/proproducts
But I've seen things that say the Smart Bridge Pro supports Sivoia QS Wireless, which does list Wood Blinds as being supported:
http://www.lutron.com/en-US/Products/Pa ... Align.aspx
I just found this comparison:
http://www.lutron.com/TechnicalDocument ... arison.pdf
which says there is no tilt functionality with the Caséta / Smart Bridge Pro, and being able to control tilt is integral to this whole plan. So I guess that is my answer, but I figured I'd post just in case someone had any insights here.
Sat Apr 18, 2020 8:11 pm
mclass offline
I have just completed the installation of 4 external blinds using Neo motors from Canada ( http://neosmartblinds.com/ ) installed by a local (Australian) blind manufacturer. Each blind has its own individual remote.
I have interfaced these to Indigo using their "Neo Smart Controller" ( http://neosmartblinds.com/smartcontroller/ ). The controller has an API (available from Neo on request) that I use to control the blinds (Up, Down, Stop and Go to Favourite are available). Using a simple Python script in an action group has allowed Indigo integration including Alexa voice control:
##NeoBlindsGENERIC_0.0
## A Python Script to to be tailored to provide required
## local control of a blind connected to a Neo Smart Controller
#   Rev 0.0 -   initial alpha script
## Import the required modules
import requests
## DEBUGGING
debug = 1 ## Set to 1 to print debug messages, to 0 for no debug
## ACTION
## Configure the action required to be sent to the target blind
## by uncommenting the ACTION required to be sent
#action = 'up' # blind moves UP
#action = 'dn' # blind moves DOWN
action = 'sp' # blind STOP moving
#action = 'gp' # go to FAVOURITE position
## BLIND ID
## Blind Code in format (get from Neo Smart App): XXX.YYY-NN
## Blind Code =
ID1 = 'XXX'
ID2 = 'YYY'
CHANNEL = 'NN'
## ASSEMBLE COMMAND
## Syntax of the command is ID1.ID2-CHANNEL-ACTION
myCommand = ID1 + '.' + ID2 + '-' + CHANNEL + '-' + action
## CONTROLLER ID
# Enter valid 24 character controller id number found in the app
# in "Your Controller"
controlID = '<INSERT YOUR CONTROLLER ID HERE>'
## CONTROLLER IP AND PORT ADDRESS
## Enter address and port number of target Controller
addr = '<INSERT YOUR CONTROLLER IP ADDRESS>'
prt = "8838"
## Assemble the request
url = 'http://' + addr + ':' + prt + '/neo/v1/transmit?command='+ myCommand +'&id=' + controlID
## Send the request and catch the response
response = requests.get(url)
## For debugging
if debug:
   # log url sent
   indigo.server.log(response.url,"URL sent was:")
   #log controller response
   indigo.server.log(response.text,"Controller response was:")
As a side comment, if there is simpler means of achieving this (Flying Diver's HTTPd plugin perhaps?) I would be please to give it a try!
The Smart Controller Module connects to your network using wifi, and needs to be located centrally to provide RF coverage to each blind.
Note that if someone clever was to upgrade the Broadlink plugin ( http://www.indigodomo.com/pluginstore/197/ ) to readily/easily learn RF commands (please, please!) I believe that you could replace the Neo controller with a much cheaper module for this and other similar RF control instances.
mclass
Sat Apr 18, 2020 8:17 pm
No, the plugin is for handling (receiving) HTTP requests, not sending them. You could simplify that script somewhat, and get rid of most of the comments, but it's really only executing one command. The rest is just fluff to build the command string.
Sun Apr 19, 2020 12:58 am
mclass wrote:
I have interfaced these to Indigo using their "Neo Smart Controller" ( http://neosmartblinds.com/smartcontroller/ ). Using a simple Python script in an action group has allowed Indigo integration.
mclass
That is almost identical to the Somfy MyLink plugin that I have in beta.
I’ll throw the above into a plugin for you this afternoon.
Peter
Sun Apr 19, 2020 1:31 am
mclass offline
At my age the “fluff” is essential to remind me what I was up to a week ago
.... and it simplifies generation of other commands
