biswasg wrote:Thanks mclass and Glenn for your responses.
I believe my issue is more of synchronising the Domfy remotes with the RFXtrx433E with RFXmngr.
As I only have MacOS computers, and RFXmngr is Windows only.
Is there MacOS equivalent for RFXmngr, or does Bond Home bypass RFXmngr requirement?
Not sure I follow, the use of the word “synchronising”
You don’t need RFXmngr - unless trying to update firmware, if have wrong one currently installed? In which case once done not needed anymore.
I likely used a windows laptop to update - so unsure as to whether an OSX version. Might be able to use a windows emulator on OSX - but that is a pure guess at my end.
The issue here unlike the cheaper Dooya blinds (which I have more off!) the protocol is transmit only. So RFXCOM plugin does not receive any info when remote buttons are pressed, and can’t just copy a remote.
The devices need to be paired with each blind which is the added step.
Once the correct firmware is installed, and the correct options selected (Blinds 123).
Then create you Indigo Device RFXCOM, Somfy, enter a unique ID
Go to RFXCOM Plugin Config Menu - Program Somfy.
Put blind in pairing mode (as per blind)
Run command for the correct Indigo Device.
Glenn
