Thingspeak Plugin Updates
Mon Dec 15, 2014 7:08 pm
Thingspeak v0.7.3 is now available.
v0.7.3:
- Changes plugin file naming conventions to correct problems with some installations. This update is only necessary for installations that do not display the plugin Config menu option.
Thu Jan 01, 2015 10:08 am
Re: Thingspeak Plugin Updates
Thingspeak v0.7.5 is now available.
- Adds plugin menu items for instant version update checking and for debug toggling.
Thu Feb 26, 2015 8:49 pm
Thingspeak v0.7.6 is now available.
v0.7.6
- Adds capability to accept local IP for Thingspeak server address.
- Better notification of device status in Indigo device list UI.
- Adds Low/Medium/High debug levels.
- Honors device start/stop comm.
- Code refinements.
IMPORTANT! This update changes the way that the plugin addresses the Thingspeak server. It is very important that you open the settings for each Thingspeak device and then select save to ensure continued operation.
The update allows users that are running their own Thingspeak servers to be able to directly address them. Within the device settings, check the "Local Server" checkbox and enter the full URL to the server (including the port number.) For example: 10..0.1.12:3000. If you are using the standard on-line version of Thingspeak, leave this box unchecked.
As always, if something doesn't seem quite right, please let me know.
Sun Aug 30, 2015 4:27 am
Thingspeak v0.7.7 is now available.
- Code refinements.
- Increases compliance with PEP8.
There is no new functionality with this update; however, the plugin should run marginally quicker.
You can download a copy of the update here.
Sat Dec 12, 2015 6:16 am
Thingspeak v0.7.8 is now available.
- Adds location settings to plugin instance.
- Adds Indigo Menu item to request data upload.
- Adds Indigo Action item to request data upload.
- Enhances UI feedback for communication and status.
Bug fixes and code enhancements:
- Changes url for update checker to use https.
- Enhances plugin preference handling and testing.
- Enhances debug logging.
- Fixes bug in upload interval timing.
Sun Dec 18, 2016 8:06 pm
Thingspeak v1.0.01 is now available.
There is no new functionality within the plugin. This release moves the project to GitHub and bumps the version number.
Mon Mar 06, 2017 7:08 am
Thingspeak v1.0.02 is now available.
  • Adds menu item to enable/disable all plugin devices.
  • Simplifies Thingspeak device configuration.
  • Moves support URL to Github.
  • Properly sets icon state to off when plugin is disabled.
  • UI refinements.
  • Code refinements.
Mon Sep 04, 2017 5:31 am
Thingspeak v1.1.01 is now available.
This update is a complete refactoring of the plugin and may not be compatible with prior versions. You should be able to reconfigure each Thingspeak device individually and continue to use existing devices once they have been reconfigured. It is probably best to disable all Thingspeak devices before applying this update, and reconfigure each device one at a time.
  • Adds a plugin menu tool to create a new Thingspeak channel.
  • Adds a plugin menu tool to update an existing Thingspeak channel.
  • Adds a plugin menu tool to list all existing Thingspeak channels.
  • Adds a plugin menu tool to clear all data from an existing Thingspeak channel.
  • Adds plugin configuration item for the Thingspeak API Key.
  • Adds Thingspeak channel ID to the address field in the Indigo Device UI pane.
  • Changes device configuration to use a channel picker rather than having to enter api key.
  • Changes device configuration to allow each device to update on its own time table. Note that the update time won't be precise but will be within 2-3 seconds.
  • Adds Twitter integration.
  • Increments Python requirement to Python 2.6.
  • Converts from using subprocess module to requests module.
  • Improved speed - especially when device configuration dialogs are opened.
  • Adds more information for plugin validation checks.
  • Adds more information about state of data uploads.
  • Adds ability to customize where the plugin log is stored.
  • Error trapping refinements.
  • UI refinements.
  • Code refinements.
  • Stylistic changes to Indigo Plugin Update Checker module.
Wed Sep 06, 2017 4:09 pm
Thingspeak v1.1.02 is now available.
  • Fixes a couple of bugs for users upgrading from prior versions.
If you are running v1.1.01 without errors, there is no need to apply this update.
Sun Oct 22, 2017 9:34 am
Thingspeak v1.1.03 is now available.
  • Under-the-hood code refinements
  • Adds note to documentation that the plugin requires Internet access to function.
Mon Feb 05, 2018 2:19 pm
Thingspeak v1.1.05 is now available.
v1.1.05
  • Updates help link to wiki.
  • Updates plugin update checker to use curl to overcome outdated security of Apple's Python install.
v1.1.04
  • Moves documentation to wiki
  • IPS configuration
Thu Mar 01, 2018 8:55 pm
Thingspeak v1.1.06 is now available.
  • Improves validation of API Key by reaching out to ThingSpeak to confirm it's valid.
  • Improves handling of datetime objects when tzinfo format changes.
  • Improves handling of Internet loss.
You can download it here.
Mon Mar 05, 2018 4:30 am
Thingspeak v1.1.07 is now available.
  • Plugin menu option to "Upload Data Now" now works regardless of the next scheduled update.
  • Fixes bugs in plugin configuration validation:
    • Users with local ThingSpeak server implementations couldn't enter API key information.
    • TypeError bug in validation for the Elevation setting.
  • Expands use of DLFramework.
  • Refines logging and exception handling.
Users whose plugins are running without error can skip this update.
Fri May 18, 2018 4:04 pm
Thingspeak v1.2.01 is now available.
  • Now requires Indigo 7.0
  • Updates Indigo API to 2.0
  • Removes custom log file handling. After applying this update, users can safely delete the custom log file.
Prior versions of the Thingspeak plugin maintained a special debug log that is no longer needed with Indigo 7. Therefore, you can safely delete the log file (and the folder if the log is the only thing in it). If you don't recall the location of the file (the plugin setting is now gone), you can look at the Indigo Events Log output at the time the update was applied--the path and file name were written to the log.
Please be careful when posting debug output on the forums or other public place.
You can download the latest version of the plugin here.
You can view the plugin documentation here.
Mon Feb 18, 2019 7:44 am
Thingspeak v1.2.07 is now available.
NOTICE: Due to changes to the Thingspeak pricing model, the Thingspeak Plugin has been deprecated. I will continue to fix bugs and answer questions, but all feature development has stopped.
v1.2.07
  • Adds notice that plugin is deprecated.
  • Code refinements.
v1.2.06
  • Synchronize self.pluginPrefs in closedPrefsConfigUi().
v1.2.05
  • Audits kDefaultPluginPrefs.
v1.2.04
  • Removes plugin update checker.
v1.2.03
  • Changes "En/Disable all Fantastic Weather Devices" to "En/Disable all Plugin Devices".
v1.2.02
  • Updates Actions support URL.
  • Code refinements.
