Question on severe weather alert text
Wed May 09, 2018 7:08 am
norcoscia offline
Hi Dave, could you tell me if it is possible to capture the full text of a severe weather alert. I know when we get one I see it in the log but I can't figure out where it is held in indigo. I would like to use it to paste into a Alexa notify me message but not sure how to go about getting the severe weather alert text into the script.
Jay provided some examples of how to use the notify me skill here
viewtopic.php?f=123&t=20641#p159895
_______
Norm
Wed May 09, 2018 7:15 am
Re: Question on severe weather alert text
It's in the alertMessage1 (alertMessage2, etc) state value. I use the following script to email me any alert messages.
wsStates = indigo.devices[665073353].states #
def sendAlertEmail(alert, message, expires):
   theSubject = "Cape Coral Weather Alert: %s" % alert
   theBody = "%s\n\nThis weather alert is valid until %s" % (message, expires)
   bePlugin = indigo.server.getPlugin("com.flyingdiver.indigoplugin.betteremail")
   if bePlugin.isEnabled():
      bePlugin.executeAction("sendEmail", deviceId=1422637605,
      props={'emailTo':'joe@foo.bar, 'emailSubject': theSubject, 'emailMessage': theBody})
   return
if wsStates[u'alertDescription1'] != ' ':
   sendAlertEmail(wsStates[u'alertDescription1'], wsStates[u'alertMessage1'], wsStates[u'alertExpires1'])
if wsStates[u'alertDescription2'] != ' ':
   sendAlertEmail(wsStates[u'alertDescription2'], wsStates[u'alertMessage2'], wsStates[u'alertExpires2'])
if wsStates[u'alertDescription3'] != ' ':
   sendAlertEmail(wsStates[u'alertDescription3'], wsStates[u'alertMessage3'], wsStates[u'alertExpires3'])
if wsStates[u'alertDescription4'] != ' ':
   sendAlertEmail(wsStates[u'alertDescription4'], wsStates[u'alertMessage4'], wsStates[u'alertExpires4'])
Wed May 09, 2018 7:37 am
Joe's right. You can add a bit of extra efficiency too, by keying on the state 'alertStatus'. That state will be 'false' if there are no severe alerts reported. Note that it's stored as a string so you'd have to:
if wsStates[u'alertStatus'] == 'true':
Wed May 09, 2018 7:54 am
That's actually the trigger for the above script. ;)
Wed May 09, 2018 8:01 am
norcoscia offline
BIG, BIG thank you to the both of you for the help - this will be really cool if I can get it working. Seems like with the right code you guys can get Indigo to do almost anything - control your flying cars, verify the transport target date for your time machines.... :lol:
_______
Norm
Wed May 09, 2018 8:41 am
norcoscia offline
Since I don't have anyway to test this -- wondering if one of you could look and let me know if any syntax issues or logic problems... :?:
import json, requests
# Get the access code from an Indigo variable - you could also just
# paste in the string, but this is much more reusable. Just create
# a new Indigo variable (name doesn't matter) and paste in the
# access code you got in the email from notifymyecho.com and
# use that varible's ID here
access_code = indigo.variables[1731541178].value # ID of variable with access code
wsStates = indigo.devices[95266216].states #Weather Underground Alert device states
#if wsStates[u'alertStatus'] == 'true': #Assuming this is in a separate external trigger
  notification_string = wsStates[u'alertDescription1'] + wsStates[u'alertMessage1’] + “ Expires ” + wsStates[u'alertExpires1']
  notification_string = wsStates[u'alertDescription2’] + wsStates[u'alertMessage2’] + “ Expires ” + wsStates[u'alertExpires2’]
  notification_string = wsStates[u'alertDescription3’] + wsStates[u'alertMessage3’] + “ Expires ” + wsStates[u'alertExpires3’]
  notification_string = wsStates[u'alertDescription4’] + wsStates[u'alertMessage4’] + “ Expires ” + wsStates[u'alertExpires4’]
body = json.dumps({
    "notification": notification_string,
    "accessCode": access_code,
requests.post(url="https://api.notifymyecho.com/v1/NotifyMe", data=body)
_______
Norm
Wed May 09, 2018 8:43 am
Be very careful, though. If you tell Indigo to do something in the past, it *WILL* do it.
When a light turns on and I can't figure out why, I usually chalk it up to Future Me doing something to mess with Past Me.
Wed May 09, 2018 8:47 am
You've got indentation issues which will cause Python to choke.
Also, if there's more than one Alert set, you're only going to get the last one. That's why mine has the notification in a function that can be called for any of the alert messages.
Wed May 09, 2018 8:49 am
norcoscia offline
Knowing me - I'm pretty sure, future me, would be too lazy to bother with present me - he (me) is more likely to be taking a nap on a floating futuristic bed (with built in refrigerator).
_______
Norm
Wed May 09, 2018 8:51 am
norcoscia offline
Thanks Joe - time for me to get my wife to help me - she has a CS degree but does not share my love of HA :-)
_______
Norm
Wed May 09, 2018 10:44 am
I would also suggest that you might not want to send the entire alert message to the echo for an announcement. They can be exceedingly long and, if there are two or three alerts, I could see that becoming exceptionally annoying--especially give that there is often shorthand and codes in body of the message. I'd suggest not using the alert message and limiting the announcement to just the description and expiration.
Thought being: echo announces "thunderstorm warning" and then that would prompt you to look at the description.
Wed May 09, 2018 12:08 pm
norcoscia offline
Good point Dave, maybe I'm over doing it. Simpler is sometimes better. Thanks again for your great Indigo plug-in work :D
PS. But I still want a robot :D
_______
Norm
