Weather Alert (alert vs no alert)
Posted:
Sun Apr 01, 2018 10:06 am
by bsp9493
Questing...
I have 2 weather triggers setup - one to to create and display text when there is an active weather alert, and one to create and display different text when there in NO active weather alert.
ie
Trigger
Type: WUnderground 7 Event
Event: Severe Weather Alert
This one works great, and activates as expected. I am actually using the Dynamic Control plugin, to create a box of a certain color, then overlay text on it and display in my Weather Control Page.
The issue i am having is, what do I use for a Trigger to identify when there is no longer a Severe Weather Alert?
I have tried a number of things, most recently...
Trigger
Type: Device State Changed
Device: myWeather
Alert - Status (I have tried a number of the available options from the dropdown here)
Becomes Equal to: False
Unfortunately, the above does NOT activate my "trigger" event (nothing in logs and then nothing to act on to to change the dynamic box I am using based on the new trigger.
WUnderground 7 events appear to be only Severe Weather Alert or Weather Location offline. Is there a way to monitor Severe Weather Alert (active or not active)?
Thanx in advance.
Dave
Re: Weather Alert (alert vs no alert)
Posted:
Sun Apr 01, 2018 11:10 am
by DaveL17
Sorry that you're having trouble. There is not currently a way with built-in triggers to fire a trigger when there is no severe weather alert. But you should be able to build your own as you are trying to do. It is important to note that the 'alertStatus' field contains text ["true"/"false"] and not a binary [True/False] value (this is a short-coming of the plugin)*. So, consider this example:
- Code: Select all
status = indigo.devices[1149686816].states['alertStatus']
indigo.server.log(str(status == False))
indigo.server.log(str(status == 'false'))
>>> False
>>> True
You'll need to set your trigger to fire when the device state 'alertStatus' becomes equal to the string 'false' or 'true' and not when it becomes the binary value False or True.
* This short-coming will probably be changed in some future version, but the decision to change it is non-trivial as it will break existing users' logic--which is not a small thing. This is why I've left it as a string for as long as I have.
Posted:
Sun Apr 01, 2018 12:21 pm
by bsp9493
yes, makes sense.
Thank you... I'll play with that and let you know if I have any further issues:)
one other thing...
In the daily e-mail summary - rain rate and accumulation are showing as 'nm' in metric. Should be "mm"?
I keep fixing it locally in mine, but if you could add that fix to your next release it would be appreciated. Not sure if it appears anywhere else, but those are the 2 spots i noticed it.
today_qpf_metric = u"{0} nm.".format(self.floatEverything(state_name="sendMailQPF", val=today_qpf_metric))
today_qpf_standard = u"{0} in.".format(self.floatEverything(state_name="sendMailQPF", val=today_qpf_standard))
today_record_high_metric = u"{0:.0f}C".format(self.floatEverything(state_name="sendMailRecordHighC", val=today_record_high_metric))
today_record_high_standard = u"{0:.0f}F".format(self.floatEverything(state_name="sendMailRecordHighF", val=today_record_high_standard))
today_record_low_metric = u"{0:.0f}C".format(self.floatEverything(state_name="sendMailRecordLowC", val=today_record_low_metric))
today_record_low_standard = u"{0:.0f}F".format(self.floatEverything(state_name="sendMailRecordLowF", val=today_record_low_standard))
yesterday_high_temp_metric = u"{0:.0f}C".format(self.floatEverything(state_name="sendMailMaxTempM", val=yesterday_high_temp_metric))
yesterday_high_temp_standard = u"{0:.0f}F".format(self.floatEverything(state_name="sendMailMaxTempI", val=yesterday_high_temp_standard))
yesterday_low_temp_metric = u"{0:.0f}C".format(self.floatEverything(state_name="sendMailMinTempM", val=yesterday_low_temp_metric))
yesterday_low_temp_standard = u"{0:.0f}F".format(self.floatEverything(state_name="sendMailMinTempI", val=yesterday_low_temp_standard))
yesterday_total_qpf_metric = u"{0} nm.".format(self.floatEverything(state_name="sendMailPrecipM", val=yesterday_total_qpf_metric))
Thanx again for the help.
d
Posted:
Sun Apr 01, 2018 12:27 pm
by DaveL17
bsp9493 wrote:In the daily e-mail summary - rain rate and accumulation are showing as 'nm' in metric. Should be "mm"?
Why yes, yes they should. This is now fixed and will be available in the next version of WUnderground 7.
Thanks for reporting it!
Posted:
Sat Apr 07, 2018 8:43 am
by bsp9493
Thanx for this... while I understand your example, I still can't seem to get my trigger to fire with NO alert (False or 'false')
>>> False
>>> True
maybe I am going about this the wrong way:( Based on the above, I have created a variable named alertStatus and I am trying fire the trigger based on that variable value.
I have tried using the Variable Changed Type and set alertStatus variable to watch for ...
"becomes false"
"becomes equal to" (and used both False and 'False'
do I need to build my trigger a different way?
Thanx in advance.
dave
Posted:
Sat Apr 07, 2018 11:55 am
by DaveL17
We may be using different terminology, but what I would suggest (if I understand your example) is to create a Device State Changed trigger like this:
- Screen Shot 2018-04-07 at 12.44.44 PM.png (26.2 KiB) Viewed 630 times
That *should* work. If that doesn't work, place your cursor in the text field, hit COMMAND-A, delete everything and retype false in to the field (there could be a space or hidden character in there that you can't see)..
