Condition not seeing WU data
Sat Mar 11, 2017 11:34 am
CraigM offline
I just stumbled upon this today by accident.
I have a sprinkler schedule, and one of the conditions is:
If device > WU 10-day forecast > High Day 1 > is greater than > 84
In the WU UI list the d01_high =95 is there, but the sprinklers did not run.
If I capture the d01_high in a variable and make the condition:
If variable > CurrentDayHigh > is greater than > value 84
it works fine
Any thoughts?
WU 1.0.04
EDIT: I use this same logic elsewhere such as setting HVAC set points, and it works fine:
If device > WU 10-day forecast > High Day 1 > is between > 84 and 100
Sat Mar 11, 2017 5:46 pm
Re: Condition not seeing WU data
You've got me there. I took a look at the device definition and it's properly established as a 'float'. I looked at my development testbed and that looks okay too.
Please try creating a second one and see if that behaves properly.
