Satellite Image Downloader not working
Thu Feb 23, 2017 8:24 pm
Monstergerm offline
I am trying this device for the first time. I am not sure I totally understand this, but here is what I did:
After setting up the device I entered for source location (key is my WU key):
http://api.wunderground.com/api/key/radar/q/pws:KCASANDI170.png?radius=20&width=280&height=280&newmaps=1
and for destination location:
file:///Users/MacMini/Pictures/WU_Radar_Images
The source location URL works fine in a web browser. But Indigo gives me the plugin error: ... cannot determine age of data. Skipping until next scheduled poll.
What is wrong?
[Moderator edit: wrapped URL in a URL tag]
Thu Feb 23, 2017 9:02 pm
Re: Satellite Image Downloader not working
Hmmm. I'm going to look into that some more. There's something that's coming up weird for me though, when using your URL. I get this in a browser:
Screen Shot 2017-02-23 at 8.55.21 PM.png (12.77 KiB) Viewed 1329 times
The URL that I use is this one (which was a copied source URL from a WUnderground web page and doesn't require a hit to the API).
http://radblast.wunderground.com/cgi-bin/radar/WUNIDS_map?station=LOT19&brand=new&num=6&type=N0R&frame=0&noclutter=1&t=1378646755&min=2&delay=30
WU has made more radar stuff available through the API and I have it on my longer-term list to look into what that means for us.
Thu Feb 23, 2017 9:14 pm
@monstergerm: Please try changing your destination location from this:
To this:
/Users/MacMini/Pictures/WU_Radar_Images/radar.png
and see if that doesn't get you going.
Dave
Fri Feb 24, 2017 12:08 pm
Monstergerm offline
My api URL should work too in Safari, it looks like you got the radar part (rain clouds) but not the map background in your screenshot. Definitively weird.
I tried your URL, which works fine in Safari, but still gives me the same "age of data" error in the plugin. I would think that the plugin just calls for an image download from the specified URL, so I am not sure where there would be a date associated with this. Perhaps the plugin has a date check routine that needs to be turned off for image downloads.
Fri Feb 24, 2017 12:34 pm
I'm stumped. There is no date check for the Image Downloader at all -- you could use it to download the daily XKCD if you wanted to[*].
I applied your URL (with my key of course) and it works fine.
Did you change your destination location too? The one you posted above isn't valid.
Dave
[*] it's possible that the error is actually elsewhere and is merely being trapped by the "out of date data" error trap.
Fri Feb 24, 2017 6:37 pm
Monstergerm offline
Yes, I changed the location field too.
I think I figured out the problem. When I turned debugging on I got an error message:
WUnderground Debug Error: 'autoip' (Line 2833)
WUnderground Debug Error: 'autoip' (Line 2850)
Those are code lines in a section that should not be called by the Satellite Image Downloader.
I then replaced line 2827 if not dev.model == 'Satellite Image Downloader':
with if dev.model not in ['Satellite Image Downloader', 'WUnderground Satellite Image Downloader']:
and this fixed my problem.
Sat Feb 25, 2017 4:28 am
Aha! That would explain it. I changed the device names along the way and clearly forgot one.
Thanks for hunting that down. I'll add it to the next release.
