Wind Direction Graphics
Sun Aug 31, 2014 8:44 pm
Wind Direction graphics for use with the WUnderground Plugin. To use the files, unzip the archive into the following directory: /Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/images/controls/devices
The file can be downloaded here:
https://github.com/DaveL17/Graphics
Here's a sample of what's in the file:
The arrow points to the direction where the wind is coming from. It's designed to have the speed value placed in the middle of the circle, but that doesn't mean that you have to do it that way. There is also a Photoshop PSD file in the archive, in case you want to make it your own.
EDIT - here's an example of the file "in action."
Screen Shot 2014-09-26 at 9.33.56 PM.png (80.99 KiB) Viewed 1922 times
Cheers
Dave
Tue Mar 17, 2015 8:15 pm
Re: Wind Direction Graphics
A grey version of the above graphic is available via this link:
https://www.indigodomo.com/library/354/
Tue Mar 17, 2015 8:25 pm
Here's another wind direction graphic that I made while monkeying around with Art Text 2. There are extra components within the file (choice of pointers, a label, etc.) that could be made visible. The graphic is 100 x 100, but should resize fairly well.
WUnderground Wind Direction Gauge
I've also included the .artx package within the archive--feel free to modify at will. I only ask that you make your version available here for others.
Cheers!
Dave
https://www.indigodomo.com/library/360/
Sun Dec 10, 2017 5:48 am
