WUnderground Plugin Updates
Thu Jul 20, 2017 5:53 am
Re: WUnderground Plugin Updates
WUnderground Plugin v1.1.10 is now available.
  • Fixes 'key windUnits not found in dict' error.
Users that do not see this error with v1.1.9 do not need to apply this update.
You can download it here.
Wed Aug 02, 2017 4:12 am
WUnderground Plugin v1.1.11 is now available.
  • Fixes bug that caused errors for some 10-day forecast devices where standard weather units didn't update for high and low temperature.
Thu Sep 07, 2017 11:05 am
WUnderground Plugin v1.1.12 is now available.
  • Adds four day weather forecast icons to WUnderground Weather device.
  • Fixes bug in WUnderground Radar devices where location parameter is used.
  • Fixes bug in Weather devices for location state value.
  • Standardizes plugin menu item styles. Menu items with an ellipsis (...) denote that a dialog box will open. Menu items without an ellipsis denote that the plugin will take immediate action.
Thu Sep 14, 2017 4:03 pm
WUnderground Plugin v1.1.13 is now available.
  • Removes logging of new forecast icon states for devices with metric values.
Mon Oct 09, 2017 5:11 am
WUnderground Plugin v1.1.14 is now available.
  • Fixes bug in WURadar device when using location type (bug does not affect bounding box or radius settings).
Thu Oct 12, 2017 5:28 am
WUnderground Plugin v1.1.15 is now available.
It is recommended that all users apply this update to avoid having a control page radar image break as a result of a future update.
Changes:
  • Eliminates coercion of image file names that are downloaded using the WURadar device type. Now, all images downloaded with this device will be saved as GIF files. PNG will no longer be supported. If PNG is somehow a requirement, users will need to use the WUnderground Image Downloader device type.
  • Adds timeout to all data download requests (10 second timeouts).
Notes:
When initially released, the WURadar device would take the GIF file that was delivered by Weather Underground and save it with a PNG extension (it did not change the underlying encoding of the image file). This was done to "trick" Indigo into showing the image filename as a static image on the Control Page editor. This version of the plugin eliminates that coercion and saves the file as a GIF file.
If you used this device in combination with a static image on a control page, it will require you to revise the radar image control on your control pages. Instead of a static image, you should change the control to a Refreshing Image URL control and enter the URL for the image using these steps:
1. Type file:// into the URL field of the Control Page editor
2. Browse to the downloaded radar image file in Finder. It will be located in the /Library/Application Support/Perceptive Automation/Indigo 7/IndigoWebServer/images/controls/static/ folder (replacing "Indigo 7" with your current version number as needed)
3. Right-click on the file and hold down the Option key
4. Click on "Copy xxx.gif as Pathname"
5. Paste this path into the URL field of the Indigo Control Page editor after the file:// you added earlier.
6. Optional: replace the spaces in the URL with %20 to silence any 'malformed URL' messages.
Your properly formatted URL will look something like this:
file:///Library/Application%20Support/Perceptive%20Automation/Indigo%207/IndigoWebServer/images/controls/static/WUradar.gif
Sun Oct 15, 2017 9:12 am
WUnderground Plugin v1.1.16 is now available.
  • WURadar Device: Will now only attempt to write a new image file when WU server responds with a success code.
Sun Oct 22, 2017 11:20 am
WUnderground Plugin v1.1.17 is now available.
- Under-the-hood code refinements.
- Adds note to documentation that the plugin requires Internet access to function.
Fri Oct 27, 2017 6:08 am
WUnderground Plugin v6.0.01 is now available.
Note:
The WUnderground Plugin is being bumped to version 6. This is to indicate that it is compatible with Indigo 6 (v1.1.0 of the Indigo API to be precise). This release (WUnderground v6.0.1) will be the last version to receive any new features. Don't Panic! Should any remaining bugs appear in WUnderground 6, I will do my best to fix them.
The next version of the WUnderground plugin will be named WUnderground 7 and will be bumped to at least v2.0.0 of the Indigo API. All new features from this point forward will be targeted to version 7. WUnderground 7 will not be compatible with Indigo 6.
v6.0.01 (1.1.18)
  • Revises the time at which the API call count is reset to correspond to Weather Underground's call count reset time of (00:00 US/Pacific).
  • Changed plugin configuration category "Value Precision" to "Value Display" to more accurately represent the category with the addition of...
  • Adds plugin configuration setting to adjust how dates and times are displayed.
  • Four new states to the Astronomy device type:
    • Sunrise epoch
    • Sunrise string
    • Sunset epoch
    • Sunset string
  • Simplifies plugin configuration dialog.
  • Changes list order of "Value Display" settings to alphabetical.
  • Reduces lines written to debug log.
  • Fixed bug in setting of Address field in Indigo UI for metric Weather devices.
Sat Oct 28, 2017 11:48 am
WUnderground Plugin v6.0.02 is now available.
Note:
The WUnderground Plugin is being bumped to version 6. This is to indicate that it is compatible with Indigo 6 (v1.1.0 of the Indigo API to be precise). WUnderground v6.0.1 will be the last version to receive any new features. Don't Panic! Should any remaining bugs appear in WUnderground 6, I will do my best to fix them.
v6.0.2
- Fixes bug where the [sunriseMinuteSunphase] device state was set incorrectly.
- Fixes bug where the sunset (moonphase) time was reported incorrectly.
Sun Nov 05, 2017 12:19 pm
WUnderground Plugin v6.0.03 is now available.
Note:
v6.0.03
- Fixes bug where WU sends nonsense epoch value for API data.
Tue Nov 07, 2017 7:01 am
WUnderground Plugin v6.0.04 is now available.
Note:
v6.0.04
  • Adds additional error handling when Weather Underground sends a data value that is not the of proper Type (i.e., list or dict instead of an expected string).
Tue Nov 21, 2017 9:34 pm
WUnderground Plugin v7.0.03 is now available.
Announcing version 7 of the WUnderground plugin. I've built this update so that existing users of version 6 (and below) should be able to install this update on top of the existing plugin, requiring no changes to existing devices. That's the plan, anyway...
NOTE! WUnderground 7 requires Indigo 7
In addition to all features provided with WUnderground 6, version 7 of the plugin has the following features and revisions.
  • Adds button to plugin config dialog to open browser session with Weather Underground for new users to sign up for API key
  • Adds setting to all weather devices to allow users to control time of day setting to receive weather email summary
  • Implements API 2.0 (requires Indigo v7)
  • Takes advantage of Indigo API improvements for device state updates (uses fewer system resources)
  • Takes advantage of Indigo API improvements for debug logging
  • Limits list of devices for severe weather alert trigger to only weather devices (only weather devices have alert information available)
  • Removes call to forecast API (because forecast10day includes everything forecast does)
  • Code consolidation using common code framework
  • Moves plugin documentation to Github wiki
  • Code refinements
  • Plugin UI refinements
Mon Feb 05, 2018 2:26 pm
WUnderground Plugin v7.0.05 is now available.
7.0.05
  • Improves robustness when Weather Underground is not responding.
  • Cleans up European weather alert attribution to remove HTML tags.
  • Updates plugin update checker to use curl to overcome outdated security of Apple's Python install.
7.0.04
  • Corrects info.plist reference to API version.
  • Adds attribution to Indigo log when the plugin is initialized.
Wed Mar 21, 2018 7:58 pm
7.0.07
  • Improves UI experience when weather locations go offline.
  • Improves UI experience when user changes device settings (while waiting for the next API call).
  • Adds API 2.0 device state updates to weather devices (fewer resources used, speed increased).
  • Fixes bug in setting WindShortString state for weather devices.
  • Fixed bug in Ten Day Forecast devices for setting for rain and snow default units.
  • Adds version check to ensure that user is running Indigo 7 or greater.
7.0.06
  • Fixes bug in severe weather alert data attributions.
