WUnderground Plugin Updates
Mon Jul 20, 2015 6:47 pm
Re: WUnderground Plugin Updates
WUnderground Plugin v0.9.14 is now available.
- Updates email summary to include all units (Metric, Mixed, Mixed SI, Standard)
- Adds option to suppress severe weather alert logging for individual weather devices.
- Fixes bug in email summary configuration parameters where the plugin tries to send email when preference is for none.
In a rush to get a fix out for the email summary configuration bug, I have not been able to fully test the other two enhancements. They should be okay, but I can't make any promises. Strongly suggest that backups be made before updating to this version.
You can download it here.
Tue Jul 21, 2015 3:49 am
WUnderground Plugin v0.9.15 is now available.
- Fixes bug in forecast email method where plugin unable to send email.
Mon Jul 27, 2015 7:23 pm
WUnderground Plugin v0.9.16 is now available.
v0.9.16
- Fixes Unicode bug (Unicode element is not callable.)
Sun Aug 02, 2015 6:34 am
WUnderground Plugin v0.9.17 is now available.
v0.9.17
- Fixes another Unicode bug (Unicode element is not callable.)
Sun Aug 16, 2015 3:28 pm
WUnderground Plugin v0.9.18 is now available.
v0.9.18
- Fixes a bug in the parsing of hourly forecast data.
Fri Aug 28, 2015 3:58 am
WUnderground Plugin v0.9.20 is now available.
- Refines email forecast and adds additional forecast period (i.e., Monday and now Monday night.)
- Refines UI notices during plugin refreshes and reloads.
- Adds Indigo custom device icon enumeration (device list, Indigo Touch, etc.)
- Code refinements:
    - Increases compliance with PEP8.
    - Improves compliance with WU TOS.
- Fixes minor bug in suppression of severe weather alerts.
- Fixes minor bug in default plugin setting for debug.
Fri Aug 28, 2015 8:16 pm
WUnderground Plugin v0.9.21 is now available.
- Fixes bug in encoding for Standard Plus Metric display preference.
- Fixes string format error bug.
Tue Sep 22, 2015 8:48 pm
WUnderground Plugin v0.9.22 is now available.
- Adds additional support for precipitation to hourly forecast devices:
    - quantitative precipitation forecast (QPF)
    - snow forecast
- Enhances error trapping.
Thu Sep 24, 2015 8:44 pm
WUnderground Plugin v0.9.23 is now available.
- Hotfix to correct implementation of QPF and Snow forecasts.
Sun Sep 27, 2015 5:11 am
WUnderground Plugin v0.9.24 is now available.
- Hopefully fixes the implementation of QPF and Snow forecasts once and for all.
Tue Sep 29, 2015 8:06 pm
WUnderground Plugin v0.9.25 is now available.
- Doubles the forecast states for standard Weather Devices (foreTitle and foreText).
- Further standardizes Trigger and Action Item labels among devices.
- Fixes a bug in the definitions of certain devices states.
Tue Oct 20, 2015 6:35 pm
You have no idea how pleased I am to finally announce that WUnderground Plugin v0.9.26 is now available.
In what can only be described as a Sisyphean* update cycle, I finally decided to scrap the entire update and start over. Many apologies for taking so long to bring you:
- Fixes bug in email forecast routine causing "Send email error: empty string for float()" error.
- Properly establishes icons 5-8 in weather device forecast.
- Fixes bug causing "local variable 'avg_wind_dir_state' referenced before assignment" error.
- Fixes bug in default download frequency setting.
- As usual, some code refinements.
* (If you prefer, Data's efforts to save Lal -- "for every fix a new problem occurred, ever faster. [Dave] tried to keep ahead of it, eventually moving so fast I could no longer follow his movement, but still it was not enough...")
Thu Oct 22, 2015 7:02 pm
WUnderground Plugin v0.9.26a is now available.
This is a hot fix that fixes a bug in the parsing of tide information. Users that rely on tidal information (that have updated to 0.9.26) should apply this fix.
Users that have not updated to v0.9.26 should be okay (and should be safe to update to v0.9.26a if desired.)
Dave
Mon Oct 26, 2015 8:03 pm
WUnderground Plugin v0.9.27 is now available.
- Fixes bug in weather device history data when Metric preference selected.
- Fixes bug in update checker (updates url to use https.)
- Fixes bug in parsing of tide info (not all arguments converted during string formatting.)
- Removes all urllib2 hooks since we don't use that anymore.
- Simplifies code related to the main thread and refresh weather data method, consolidating all code into a single method.
- Significantly simplifies code for dumping JSON data to the log.
- Further refines debug logging.
The most significant change is the way that weather data is written to the log folder. This is only done on user request (from the plugin menu.) As a part of this change, we are now keeping a copy of the entire weather data dictionary in memory. The cost is roughly 225Kb per location (not per device.)
As always, please let me know if something doesn't seem quite right.
Dave
Sun Nov 08, 2015 3:48 pm
WUnderground Plugin v0.9.28 is now available.
- Adds an error trap for WU return where history data is called for but is not returned.
- Adjusts forecast email text to include probability of precipitation for the forecast evening period. This avoids the weirdness where the text would show 0% chance of daytime precipitation and then a non-zero amount of total QPF.
- Simplified import of datetime module.
