WUnderground Plugin Updates
Fri Apr 06, 2018 6:32 pm
Re: WUnderground Plugin Updates
WUnderground Plugin v7.0.09 is now available.
7.0.09
  • Rounds off values for weather device forecast values. Some PWSs will report decimal-level precision even though it's unlikely that they mean to.
  • Changes to the poll frequency and Temperature Item List plugin preferences now take effect when preferences are saved (all other display preferences continue to take effect during the next scheduled poll.)
  • Standardizes all timeouts at 20 seconds (from 10 seconds) and reduces the urllib backup timeout to 20 seconds (from 30 seconds). Timeouts now 20 seconds across all calls.
  • Adds validation for weather location offline trigger settings.
  • Limits weather location offline triggers to one per location.
  • Improves indication of offline weather sites (improves upon v7.0.08).
  • Improves handling of Indigo UI images for on/offline.
  • Fixes bug where changes to weather location offline trigger were made while the trigger was disabled.
  • Fixes typo in metric forecast email ('mm' instead of 'nm').
  • Code enhancements.
7.0.08
  • Adds new plugin configuration option for pressure trend display.
  • Improves indication of offline weather sites.
7.0.07
  • Improves code commenting and adds Sphinx compatibility to docstrings.
  • Improves UI experience when weather locations go offline.
  • Improves UI experience when user changes device settings (while waiting for the next API call).
  • Adds API 2.0 device state updates to weather devices (fewer resources used, speed increased).
  • Fixes bug in setting WindShortString state for weather devices.
  • Fixed bug in Ten Day Forecast devices for setting for rain and snow default units.
  • Adds version check to ensure that user is running Indigo 7 or greater.
7.0.06
  • Fixes bug in severe weather alert data attributions.
You can download it here.
Obviously, there are a lot of changes and there could be gremlins. If you find any errors, please report them and I'll try to turn them around as quick as possible.
I want to make a special shoutout to forum user @Monstergerm who was a huge help in regression testing.
Sat Apr 07, 2018 4:01 am
WUnderground Plugin v7.0.10 is now available.
  • Fixes bug in setting timedelta for plugin refresh cycle.
Wed Jun 13, 2018 5:45 am
WUnderground Plugin v7.0.11 is now available.
IMPORTANT: due to changes in the pricing model for the Weather Underground API, development of the WUnderground plugin will cease with this release.
I will continue to provide bug fixes, but there will be no further feature development.
  • Adds new plugin configuration option for time format. 12 hour time with AM/PM (12:34 PM) or without (12:34).
  • Removes Toggle Debug option from plugin menu.
  • Coerces UI value for precipitation to always display two decimal precision (will not apply unless a valid number is provided by WU).
  • Fixes bug in hourly forecast device for rain, snow and wind state values for standard units (F and MPH) only.
Tue Jul 31, 2018 3:24 pm
The WUnderground plugin has been removed from the Indigo Plugin Store. This is to avoid confusion because WU is no longer providing API access keys.
For those that may need to re-download the plugin, you can do that via Github.
