WUnderground Plugin Updates
Sat Aug 23, 2014 6:08 pm
WUnderground v0.5.3 is now available.
This version should take care of all known bugs and tracebacks. If that's not the case, please post to the forum or PM me directly.
Sun Aug 31, 2014 8:13 pm
Re: WUnderground Plugin Updates
WUnderground v0.5.4 is now available.
This version standardizes Unicode use within the plugin.
Sat Sep 06, 2014 3:34 pm
WUnderground v0.6.0 is now available.
v0.6.0
- Rewrite of code that reaches out to Weather Underground.
- Adds 'Mixed Units' as an option for weather devices (temp values Metric, and the rest Imperial.)
- Adds a metric long string for wind (which WU doesn't provide.) "From the North at 2 KPH Gusting to 5 KPH." ( Only used when user preference is Metric. Otherwise, an empty string.)
- Alerts user in the log if the number of severe weather alerts exceeds the number tracked by the plugin (more than 4.)
- Logs attribution for European weather alerts per Weather Underground TOS.
- Hides email address field if plugin update notification set to "No".
- Fixes bug in call counter for some implementations.
- Various code refinements.
Sun Sep 07, 2014 2:10 pm
WUnderground v0.6.01 is now available.
v0.6.01
- Fixes bug in callCounter for older implementations.
Sun Sep 07, 2014 9:09 pm
WUnderground v0.6.1 is now available.
v0.6.1
- Moved code that parses weather data to devices into its own method.
- Fixes bug in temperature display caused by inclusion of Mixed units.
Fri Sep 12, 2014 7:57 pm
WUnderground v0.6.2 is now available.
v0.6.2
- Added more robust debug output.
IMPORTANT: please don't make the debug output public or you will expose your API key. Either PM the output directly to me or scrub it before posting it publicly.
Tue Sep 16, 2014 7:53 pm
WUnderground v0.6.3 is now available.
v0.6.3
- Improved call counter logic.
- Even more robust debug output.
This represents a rethinking of the call counter logic and should now (hopefully) address all known associated bugs. While the debug output is more robust, I also ramped back on the output to not include sensitive information like the apiKey and location information. It's a plan for a future version to have more control over debug (low/medium/high) much like the HousePad Plugin does.
As always, please let me know if something's not quite right.
Dave
Fri Sep 19, 2014 4:37 am
WUnderground v0.6.31 is now available.
v0.6.31
- Fixed bug in call counter to account for older installations.
- Refined control page labels (may not take effect until next reboot.)
This version of the plugin may reset your daily call counter when installed (the number
of calls for that day only.)
Sat Sep 20, 2014 4:21 pm
WUnderground v0.6.32 is now available.
v0.6.32
- Fixed bug in updater key creation for new installations.
Wed Oct 01, 2014 7:54 pm
WUnderground v0.7.0 is now available.
This is a big update. It is recommended that all users save a backup of their current plugin file just in case. As usual, please report any bugs or questions to the WUnderground forum.
v0.7.0
- Adds menu item to refresh weather information on demand (all devices).
- Adds action item to refresh weather information (all devices).
- Adds states for yesterday's high, low and precip level. Still a work in progress...
- Adds debug logging levels (Low, Medium, High):
  • Low = minimal logging.
  • Medium = all debug logging _except_ sensitive and identifying information.
  • High = includes sensitive and identifying information (API Key, location, email, etc.)
- Makes plugin preference calls more robust.
- Declutterfy plugin and device configuration dialogs.
- Refines control page and trigger labels.
- Refines WUnderground version numbering to adhere to Indigo version control.
Sun Nov 16, 2014 7:07 pm
WUnderground v0.7.01 is now available.
v0.7.01:
- UI refinements.
- Enhanced error tracking.
- Fixes bug in temperature formatting.
This is basically a maintenance release.
Sun Dec 07, 2014 4:21 pm
WUnderground v0.7.02 is now available.
v0.7.02:
- Error tracking refinements.
Mon Dec 15, 2014 7:02 pm
WUnderground v0.7.03 is now available.
v0.7.03:
- Changes plugin file naming conventions to correct problems with some installations. This update is only necessary for installations that do not display the plugin Config menu option.
Tue Dec 23, 2014 9:32 pm
WUnderground v0.7.05 is now available.
v0.7.05:
- Adds a new weather device which holds hourly forecast information for the next 24 hours. To use it, add a new device and select "WUnderground Hourly Forecast". Note that this will result in another call to Weather Underground. A future update will combine calls by location where possible.
- Adds new forecast text states to existing weather devices.
- Fixes bug where certain unicode characters didn't display properly.
IMPORTANT: please maintain a copy of your existing plugin file before upgrading. This update has run well in testing, but I can't guarantee it to be error free or provide instant support over the holidays.
Cheers and Happy Holidays!
Dave
Wed Dec 24, 2014 8:43 am
WUnderground v0.7.06 is now available.
- Adds hourly forecast time stamp as a state for hourly forecast devices.
- Fixes 'Refresh Data Now" menu item and action item to account for new hourly forecast device.
