Weather Underground Plugin
Wed Jul 19, 2017 10:57 am
Korey offline
Re: Weather Underground Plugin
DaveL17 wrote:
roquej wrote:
Upgrade to the latest version as I am looking to lower the CPU load on the Indigo server. Keeping my fingers crossed. FYI, getting the follow error:
Started plugin "WUnderground 1.1.9"
WUnderground Error Problem parsing 10-day forecast data. Error: (Line 1798 ('key windUnits not found in dict')
JP
Not sure why you wouldn't have that setting -- but that doesn't mean I can't trap the error (which I have done for the next release). Please try opening up the device settings for your 10-day forecast device and select save. Hopefully, that will clear the error.
Same error here Dave!
WUnderground
   WUnderground                    ================================================ Initializing New Plugin Session =================================================
   WUnderground                    Plugin name:                    WUnderground
   WUnderground                    Plugin version:                 1.1.9
   WUnderground                    Plugin ID:                      com.fogbert.indigoplugin.wunderground
   WUnderground                    Indigo version:                 7.0.3
   WUnderground                    Python version:                 2.7.10 (default, Jul 14 2015, 19:46:27) [GCC 4.2.1 Compatible Apple LLVM 6.0 (clang-600.0.39)]
   WUnderground                    ==================================================================================================================================
Korey
Wed Jul 19, 2017 11:13 am
Thanks Korey. That is so weird. I'm sure that it's something that I can trap going forward.
Did opening and saving the device configuration for the 10-day forecast device clear the error for you?
Wed Jul 19, 2017 11:38 am
roquej offline
Dave,
FYI: I re-saved the device as per your suggestion and error is gone now.
JP
Wed Jul 19, 2017 11:57 am
Korey offline
Hey Dave!
Yep, that was the ticket, Thanks! :D :D :D
 Reloading plugin "WUnderground 1.1.9"
   Stopping plugin "WUnderground 1.1.9" (pid 47764)
   Stopped plugin "WUnderground 1.1.9"
   Starting plugin "WUnderground 1.1.9" (pid 49944)
   WUnderground
   SQL Logger                      adding column "d02_winddirlong_ui" to table device_history_1686324399 ("10 Day forcast")
   SQL Logger                      adding column "d03_winddirlong_ui" to table device_history_1686324399 ("10 Day forcast")
   SQL Logger                      adding column "d04_winddirlong_ui" to table device_history_1686324399 ("10 Day forcast")
   SQL Logger                      adding column "d05_winddirlong_ui" to table device_history_1686324399 ("10 Day forcast")
   SQL Logger                      adding column "d06_winddirlong_ui" to table device_history_1686324399 ("10 Day forcast")
   SQL Logger                      adding column "d07_winddirlong_ui" to table device_history_1686324399 ("10 Day forcast")
   SQL Logger                      adding column "d08_winddirlong_ui" to table device_history_1686324399 ("10 Day forcast")
   SQL Logger                      adding column "d09_winddirlong_ui" to table device_history_1686324399 ("10 Day forcast")
   SQL Logger                      adding column "d10_winddirlong_ui" to table device_history_1686324399 ("10 Day forcast")
Korey
Wed Jul 19, 2017 12:02 pm
Thanks to both of you. This should not be an issue in future versions.
Thu Jul 20, 2017 5:51 am
I have just pushed a fix for the error where plugin reports 'key windUnits not found in dict'.
Users that do not see this error with v1.1.9 do not need to apply this update.
