Hi haavarda
Assuming that you are running the latest version 0.3.4 of the plugin, check that the units are set to Metric in the Wunderground device settings.
Colin
haavarda wrote:Hi,
Thank you for your plugin. I have just started to use it, and it appears to be very good!
I have one ting I find strange.
When I try to export the HI and LOW temperatures to a variable I get the value in F instead of C. The current temperature is reported in C. Any thoughts?
regards
DaveL17 wrote:Thanks @Colin for chiming in--I presume that you see forecast values in C as expected?
Dave
Error device "Wunderground" state key alertStatus not defined (ignoring update request)
Error device "Wunderground" state key alertDescription not defined (ignoring update request)
Error device "Wunderground" state key alertMessage not defined (ignoring update request)
Error device "Wunderground" state key alertExpires not defined (ignoring update request)
Wunderground Weather Underground data parsed successfully.
Wunderground Weer Balen: pws:IANTWERP23
Wunderground Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 203, in runConcurrentThread
<type 'exceptions.UnicodeEncodeError'>: 'ascii' codec can't encode characters in position 221-222: ordinal not in range(128)
Wunderground Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
colinpartridge wrote:DaveL17 wrote:Thanks @Colin for chiming in--I presume that you see forecast values in C as expected?
Dave
I am seeing the correct values now thanks. I noticed I'm getting the following error before parsing ( every 15 mins).. but I'm ignoring it.
- Code: Select all
Vaillant wrote:Hi,
Thanks so much for this plugin. Finally accurate weather for the place where I live (Europe/Belgium).
The plugin works fine but occasionally it throws up this error:
- Code: Select all
This results in a mail from Wunderground giving me a 'wunderground API usage alert'.
Reloading the plugin immediately gives the same error.
Have to wait a while before it wil work again.
Hate the ascii-encoding problem here in Europe.
Hope you have a solution?
Greetings,
Adrian
DaveL17 wrote:Please open each weather device, select Edit Device Settngs, and then select Save (you needn't change any settings.) That should solve the problem. Please let me know if that's not the case.
To help me isolate the offending code, can you please let me know what version of the plugin you are using?
DaveL17 wrote:haavarda wrote:Hi,
regards
Hello haavarda - thanks for the kind words.
In order to understand your problem, I need a little bit more information. How are you exporting the value to a variable? It would help if you could include any relevant Python or AppleScript code as well.
Dave
Vaillant wrote:This results in a mail from Wunderground giving me a 'wunderground API usage alert'.
Greetings,
Adrian
DaveL17 wrote:@Colin:
Please do me a favor and inspect the custom states for one of your weather devices--do you see blocks of states for:
alertDescription[1-4]
alertExpires[1-4]
alertMessage[1-4]
alertStatus[1-4]
Dave
DaveL17 wrote:@haavarda - I have figured out what was causing the celcius forecast to come through as fahrenheit. The plugin was downloading the metric forecast properly, but this value was then being instantly overwritten with fahrenheit values.
This will be fixed in v0.3.5.
Sorry for the trouble.
Dave
