Unable to reach Weather Underground. URLError - <urlopen err
Sun Nov 27, 2016 12:07 pm
AndersKn offline
I get errors and no data seems to be loaded from Weather Underground.
Below I have gathered the Log produced in Indigo. I have also attached the settings I have.
I am using the free plan from Weather Underground. I have updated and are running Indigo 7.0.2.
Any comment of what I am doing incorrect would be appreciated.
When I try to refresh the data I get the following errors in the Indigo Log window:
 WUnderground Error              Unable to reach Weather Underground. URLError - <urlopen error no host given> (Line 817)
 WUnderground Error              Sleeping until next scheduled poll.
Using the debug output from Underground I see that the following URL is used:
http://api.wunderground.com/api/XXXXXXXXXX
813671da849e7e02/geolookup/alerts_v11/almanac_v11/astronomy_v11/conditions_v11/forecast_v11/forecast10day_v11/hourly_v11/lang:EN/history_v11_20161126/tide_v11/q/SFO.json
(I have replaced my private key with XXXX'es.)
Using the URL in a normal browser gives:
  "response": {
  "version":"0.1",
  "termsofService":"http://www.wunderground.com/weather/api/d/terms.html",
  "features": {
   "error": {
      "type": "keynotfound"
      ,"description": "this key does not exist"
I am quite certain that I am using the correct key. ( I even re-generated the key and switched in the settings panel). This has also worked in the past.
Best regards
Anders
Setting for the Device
Settings for Wunderground
Sun Nov 27, 2016 12:55 pm
AndersKn offline
Re: Unable to reach Weather Underground. URLError - <urlopen
Playing around a bit in a web browser it seems that there is a "/" missing in the URL.
Using:
http://api.wunderground.com/api/XXXXXXXXXX813671da849e7e02/geolookup/alerts_v11/almanac_v11/astronomy_v11/conditions_v11/forecast_v11/forecast10day_v11/hourly_v11/lang:EN/history_v11_20161126/tide_v11/q/SFO.json
Will give the strange output as seen in my previous post. (My key replaced with XXX'es)
If I a "/" is inserted in the URL:
http://api.wunderground.com/api/XXXX/813671da849e7e02/geolookup/alerts_v11/almanac_v11/astronomy_v11/conditions_v11/forecast_v11/forecast10day_v11/hourly_v11/lang:EN/history_v11_20161126/tide_v11/q/SFO.json
I get a more complete result:
  "response": {
  "version":"0.1",
  "features": {
  "geolookup": 1
  "alerts": 1
  "almanac": 1
  "astronomy": 1
  "conditions": 1
  "forecast": 1
  "forecast10day": 1
  "hourly": 1
  "history": 1
  "tide": 1
   "error": {
      "type": "unknownfeature"
      ,   "location": {
      "type":"CITY",
      "country":"US",
      "country_iso3166":"US",
      "country_name":"USA",
      "state":"CA",
      "city":"San Francisco International",
      "tz_short":"PST",
      "tz_long":"America/Los_Angeles",
      "lat":"37.61888885",
      "lon":"-122.37472534",
      "zip":"94128",
(I have only posted first few lines of output).
Thus it would seem that something is not correct with the URL.
I tried to add a "/" in the setting, but this did not help.
Best regards
Anders
Sun Nov 27, 2016 2:02 pm
Hi Anders - I'm not sure what's going on with your key. When I copy your original URL and insert my key in its place, the data downloads just fine (the original URL you posted is broken over two lines, which I corrected.)
This URL works for me:
http://api.wunderground.com/api/XXXXXXXXXXX/geolookup/alerts_v11/almanac_v11/astronomy_v11/conditions_v11/forecast_v11/forecast10day_v11/hourly_v11/lang:EN/history_v11_20161126/tide_v11/q/SFO.json
I also tested the URL generated by the plugin and that works too.
