Errors when running
Mon Nov 14, 2016 6:13 am
CelticWebs offline
Errors when running
I've just installed the latest plugin and it's installed on the latest version 7 Indigo on my Mac mini server.
I can pull my EvoHome Device Id's and add each device as I'd expect.
The problem arrises when I try and use one, I get the following errors
14 Nov 2016, 12:10:47
Honeywell [Glass Radiators]: Setting HVAC Mode to: Heat
Honeywell Error Error in plugin execution ExecuteAction:
File "plugin.py", line 67, in actionControlThermostat
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Honeywell.indigoPlugin/Contents/Server Plugin/Honeywell.py", line 915, in actionControlThermostat
KeyError: key setpointHeat not found in dict
Is there a problem with the plugin or my setup please?
Mon Nov 14, 2016 7:40 am
nlagaros offline
Re: Errors when running
Would you post all log entries please from plugin startup. Also turn on debug mode - that will help isolate the issue. Thanks.
Thu Dec 22, 2016 9:55 am
mjannusch offline
I was previously on 0.4.4 and would get five errors in the log on each device refresh. On 0.5.0 I now only get one, so that's a big improvement for me as far as not spamming the log as much. Thanks!
0.4.4:
Dec 22, 2016, 9:45:54 AM
Honeywell Error [Thu Dec 22 09:45:54 2016] No value found for device: Back Garage Thermostat, field: thermostatMode
Honeywell Error [Thu Dec 22 09:45:54 2016] No value found for device: Back Garage Thermostat, field: setpointCool
Honeywell Error [Thu Dec 22 09:45:54 2016] No value found for device: Back Garage Thermostat, field: setpointStatus
Honeywell Error [Thu Dec 22 09:45:54 2016] No value found for device: Back Garage Thermostat, field: nextTime
Honeywell Error [Thu Dec 22 09:45:54 2016] No value found for device: Back Garage Thermostat, field: fanMode
0.5.0:
Starting plugin "Honeywell 0.5.0" (pid 77517)
Started plugin "Honeywell 0.5.0"
Honeywell Your plugin version, v0.5.0, is current.
Honeywell [Thu Dec 22 09:52:09 2016] Authenticated to TCC Web API.
Honeywell [Thu Dec 22 09:52:09 2016] Processed plugin preferences.
Honeywell Debug Starting device: Back Garage Thermostat
Honeywell Debug [Thu Dec 22 09:52:09 2016] Thermostat: Back Garage Thermostat, Enabled: True
Honeywell Initializing thermostat device: Back Garage Thermostat
Honeywell Debug Updating Device: Back Garage Thermostat, State: temperatureInput1, Value: 0
Honeywell Debug Updating Device: Back Garage Thermostat, State: indoorHumidityStatus, Value:
Honeywell Debug Updating Device: Back Garage Thermostat, State: indoorTemperatureStatus, Value:
Honeywell Debug Updating Device: Back Garage Thermostat, State: macID, Value:
Honeywell Debug Updating Device: Back Garage Thermostat, State: maxCoolSetpoint, Value:
Honeywell Debug Updating Device: Back Garage Thermostat, State: maxHeatSetpoint, Value:
Honeywell Debug Updating Device: Back Garage Thermostat, State: minCoolSetpoint, Value:
Honeywell Debug Updating Device: Back Garage Thermostat, State: minHeatSetpoint, Value:
Honeywell Debug Updating Device: Back Garage Thermostat, State: name, Value:
Honeywell Debug Updating Device: Back Garage Thermostat, State: nextTime, Value:
Honeywell Debug Updating Device: Back Garage Thermostat, State: outdoorHumidity, Value: 0
Honeywell Debug Updating Device: Back Garage Thermostat, State: outdoorHumidityStatus, Value:
Honeywell Debug Updating Device: Back Garage Thermostat, State: scheduleCapable, Value: False
Honeywell Debug Updating Device: Back Garage Thermostat, State: scheduleCoolSp, Value: 0
Honeywell Debug Updating Device: Back Garage Thermostat, State: scheduleHeatSp, Value: 0
Honeywell Debug Updating Device: Back Garage Thermostat, State: setpointStatus, Value:
Honeywell Debug Updating Device: Back Garage Thermostat, State: thermostatAllowedModes, Value:
Honeywell Debug Updating Device: Back Garage Thermostat, State: thermostatMode, Value:
Honeywell Debug Updating Device: Back Garage Thermostat, State: thermostatModelType, Value:
Honeywell Debug Updating Device: Back Garage Thermostat, State: thermostatVersion, Value:
Honeywell Debug Updating Device: Back Garage Thermostat, State: lastUpdate, Value:
Honeywell Debug Updating Device: Back Garage Thermostat, State: lastUpdate, Value: 1482421930.31
Honeywell Debug Updating Device: Back Garage Thermostat, State: macID, Value: 00D02D603602
Honeywell Debug Updating Device: Back Garage Thermostat, State: name, Value: Back Garage
Honeywell Debug Updating Device: Back Garage Thermostat, State: thermostatModelType, Value: FOCUS_PRO_WIFI_RETAIL
Honeywell Debug Updating Device: Back Garage Thermostat, State: thermostatVersion, Value: 02.01.03.01
Honeywell Debug Updating Device: Back Garage Thermostat, State: thermostatAllowedModes, Value: Heat,Off
Honeywell Debug Updating Device: Back Garage Thermostat, State: thermostatMode, Value: Heat
Honeywell Debug Updating Device: Back Garage Thermostat, State: setpointStatus, Value: Scheduled
Honeywell Debug Updating Device: Back Garage Thermostat, State: nextTime, Value: 2000-01-01T22:00:00
Honeywell Debug Updating Device: Back Garage Thermostat, State: temperatureInput1, Value: 45.0
Honeywell Debug Updating Device: Back Garage Thermostat, State: indoorTemperatureStatus, Value: Measured
Honeywell Debug Updating Device: Back Garage Thermostat, State: indoorHumidityStatus, Value: NotAvailable
Honeywell Error [Thu Dec 22 09:52:10 2016] No value found for device: Back Garage Thermostat, field: fanMode
Honeywell Debug Updating Device: Back Garage Thermostat, State: maxCoolSetpoint, Value: 99.0
Honeywell Debug Updating Device: Back Garage Thermostat, State: maxHeatSetpoint, Value: 90.0
Honeywell Debug Updating Device: Back Garage Thermostat, State: minCoolSetpoint, Value: 50.0
Honeywell Debug Updating Device: Back Garage Thermostat, State: minHeatSetpoint, Value: 40.0
Honeywell Debug Updating Device: Back Garage Thermostat, State: outdoorHumidity, Value: 128.0
Honeywell Debug Updating Device: Back Garage Thermostat, State: outdoorHumidityStatus, Value: NotAvailable
Honeywell Debug Updating Device: Back Garage Thermostat, State: scheduleCapable, Value: True
Honeywell Debug Updating Device: Back Garage Thermostat, State: scheduleCoolSp, Value: 78.0
Honeywell Debug Updating Device: Back Garage Thermostat, State: scheduleHeatSp, Value: 45.0
Honeywell Debug Method: runConcurrentThread
Honeywell Debug Running Concurrent Thread
Dec 22, 2016, 9:52:40 AM
Honeywell Debug Updating Device: Back Garage Thermostat, State: lastUpdate, Value: 1482421960.83
Honeywell Error [Thu Dec 22 09:52:40 2016] No value found for device: Back Garage Thermostat, field: fanMode
Dec 22, 2016, 9:53:11 AM
Honeywell Debug Updating Device: Back Garage Thermostat, State: lastUpdate, Value: 1482421991.23
Honeywell Error [Thu Dec 22 09:53:11 2016] No value found for device: Back Garage Thermostat, field: fanMode
Thu Dec 29, 2016 6:03 am
nlagaros offline
Would you be able to run the Dump JSON action against this thermostat and send me the output. I'm working on smartening up the plugin to adapt to various thermostat models. Thanks.
Tue Jan 03, 2017 4:41 pm
mjannusch offline
PM with JSON dump sent. Thanks!
Wed Jan 04, 2017 6:48 pm
nlagaros offline
Thanks. This will help. Will try to get an update out over the weekend.
Wed Feb 01, 2017 9:43 pm
mjannusch offline
Nick, is there anything you needed tested or any additional information? Thanks!
Wed Jul 05, 2017 10:19 am
nlagaros offline
I just posted an update. Check it out: http://vulture:8000/wordpress/home/honeywell-thermostats/
