Honeywell Thermostat 0.4.6 errors
Fri Oct 28, 2016 4:08 am
MartinG offline
Just installed version 0.4.6 and get errors both at startup and while running. I've copied the log file below. I'm in the UK (hence using TCC Europe), and have double checked login credentials. I'm running Indigo 6.1.11.
Here's the event log...
28 Oct 2016 10:51:29
  Installing and enabling plugin Honeywell v0.4.6
  Loading plugin "Honeywell 0.4.6"
  Starting plugin "Honeywell 0.4.6" (pid 69522)
  Started plugin "Honeywell 0.4.6"
  Honeywell                       Your plugin version, v0.4.6, is current.
  Honeywell Error                 Error in plugin execution startup:
  File "plugin.py", line 33, in startup
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Honeywell.indigoPlugin/Contents/Server Plugin/Honeywell.py", line 72, in startup
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Honeywell.indigoPlugin/Contents/Server Plugin/Honeywell.py", line 779, in closedPrefsConfigUi
KeyError: key TCCServer not found in dict
28 Oct 2016 10:52:30
  Honeywell                       [Fri Oct 28 10:52:30 2016] Processed plugin preferences.
  Honeywell Error                 Error in plugin execution runConcurrentThread:
  File "plugin.py", line 43, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Honeywell.indigoPlugin/Contents/Server Plugin/Honeywell.py", line 186, in runConcurrentThread
TypeError: unsupported operand type(s) for -: 'float' and 'NoneType'
  Honeywell Error                 plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
  Disabling plugin "Honeywell 0.4.6"
  Stopping plugin "Honeywell 0.4.6" (pid 69522)
  Stopped plugin "Honeywell 0.4.6"
Sat Nov 05, 2016 1:47 pm
nlagaros offline
Re: Honeywell Thermostat 0.4.6 errors
Just verifying that you have evohome devices? If so, did you check the evohome checkbox instead of the Wi-Fi?
