Honeywell v0.3.0 error
Posted: Thu Mar 24, 2016 4:44 pm
Recently downloaded this plugin and at first everything seemed to be working just fine. Unfortunately now I'm getting the following errors. I've disabled/re-enabled, uninstalled/re-installed to no avail. Any thoughts on how to fix? Thanks.
Mar 24, 2016, 3:37:25 PM
Indigo Cocoa client connected
Enabling plugin "Honeywell 0.3.0"
Starting plugin "Honeywell 0.3.0" (pid 22575)
Started plugin "Honeywell 0.3.0"
Honeywell Your plugin version, v0.3.0, is current.
Honeywell Debug Getting Plugin Configuration Settings
Honeywell Saved Plugin Configuration
Honeywell Debug [Thu Mar 24 15:37:40 2016] Thermostat: Thermostat-1st floor, Enabled: True
Honeywell Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 49, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Honeywell.indigoPlugin/Contents/Server Plugin/Honeywell.py", line 77, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Honeywell.indigoPlugin/Contents/Server Plugin/Honeywell.py", line 125, in initDevice
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Honeywell.indigoPlugin/Contents/Server Plugin/Honeywell.py", line 696, in updateStateOnServer
<type 'exceptions.KeyError'>: key humidityInput1 not found in dict
Honeywell Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Honeywell Debug Method: runConcurrentThread
Honeywell Debug Running Concurrent Thread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Honeywell.indigoPlugin/Contents/Server Plugin/Honeywell.py", line 89, in runConcurrentThread
<type 'exceptions.UnboundLocalError'>: local variable 'timer_refresh' referenced before assignment
