Honeywell API
Mon Dec 21, 2015 4:00 pm
petematheson offline
Re: Honeywell API
See this post here:
http://www.automatedhome.co.uk/vbulleti ... l-remotely
Script is:
import requests
import json
USERNAME = 'USERNAME'
PASSWORD = 'PASSWORD'
url = 'https://rs.alarmnet.com/TotalConnectComfort/WebAPI/api/Session'
postdata = {'Username':USERNAME,'Password':PASSWORD,'ApplicationId':'91db1612-73fd-4500-91b2-e63b069b185c'}
headers = {'content-type':'application/json'}
response = requests.post(url,data=json.dumps(postdata),headers=headers)
print response.content
userData = json.loads(response.content)
userId = userData['userInfo']['userID']
sessionId = userData['sessionId']
url = 'https://rs.alarmnet.com/TotalConnectComfort/WebAPI/api/locations?userId=%s&allData=True' % userId
headers['sessionId'] = sessionId
response = requests.get(url,data=json.dumps(postdata),headers=headers)
Mon Dec 21, 2015 4:09 pm
Re: Honeywell API
Thanks - that works so far.
Hows` the plugin coming along or have you abandoned that? :)
Peter
Mon Dec 21, 2015 5:01 pm
Re: Honeywell API
I need to nag my brother in law as I passed the torch on that one, I just don't have the time to learn python at the moment with the little one around now.
I'm also keen to get a plugin for my loop gas and electric meter - it seems to be pretty accurate so would be cool to pull in info like, current £ per minute on electricity / gas - configure warnings when usage is high for too long etc.. !
Lots more people seem to be investing in the Honeywell system though, perhaps someone else out there could come up with one? :)
Mon Dec 21, 2015 5:08 pm
Re: Honeywell API
I also haven't the time, though I will probably make some usable Indigo scripts from the evohome-client Python package that's on github in the meantime.
Tue Dec 22, 2015 1:12 am
colinpartridge offline
Re: Honeywell API
petematheson wrote:
See this post here:
Script is:
import requests
import json
Thanks for that Pete. is the requests a standard installed Python module? I'm running Indigo on a Mavericks Mac and don't have it.
Colin
Tue Dec 22, 2015 1:19 am
Re: Honeywell API
No, I had to grab it.
If you've got pip installed, then 'pip install requests' (maybe with sudo) works.
Tue Dec 22, 2015 1:24 am
Re: Honeywell API
Ok thanks, thought that might be the case.
C
Sat Dec 26, 2015 10:09 am
Re: Honeywell API
Pete/Colin,
Does your wireless relay (for the boiler) have any lights during normal operation?
I wired it up and turned it on, and bottom light flashes red at me. An RF Test confirms 5-bars signal.
Pressing the button on it turns top button green and the boiler comes on, press again and boiler goes off.
All lights now gone off.
But none of my zones are activating the boiler - I've set them all to 15', the TRV motors kick in and open the valves; I've set them all to 30', the motors kick in and close the valves.
But nothing firing the boiler on demand...?
Any ideas?
Sat Dec 26, 2015 10:23 am
Re: Honeywell API
What kind of equipment you thinking of for that? I was quite interested in the smappee one, though there was no gas module last time I checked!
Sat Dec 26, 2015 10:27 am
Re: Honeywell API
I'm using the loop ones. (Google them or check vesternet) I've found mine to be pretty accurate! Also not too costly at £70'ish for the pair
I'll have to check my box next to the boiler, not home right now but will let you know unless one of the others gets there first. Did you do the RF Comms test (if there's one) to test Comms between the wireless controller and the boiler relay?
Sat Dec 26, 2015 10:38 am
Re: Honeywell API
Yeah, Comms tests ok no problem.
Sat Dec 26, 2015 11:05 am
Re: Honeywell API
howartp wrote:
Pete/Colin,
Any ideas?
When heat is demanded from the controller the green light on the relay box is active. Given that the relay is activating your boiler then that part would appear to be working. It might be worth rebinding the relay to the Controller. I don't think mine were all paired up out of the box, so went through the binding procedure as all has been well. First time I wired the relay, I connected to the NC connection rather than NO and we had a very warm night.
Colin
Sat Dec 26, 2015 11:12 am
Re: Honeywell API
Ah yes I remember re-binding mine as I blindly followed the quick start instructions - worth giving that a go.
I have noticed that my boiler now seems to stay on the pump overrun for a while, but can't see how that would be due to the new relay box ?
Sat Dec 26, 2015 12:13 pm
Re: Honeywell API
Colin
Bingo!
That seems to have done something.
Now to get these TRVs swapped and schedules set - currently 28 degrees at the moment because the controller wasn't telling boiler to go off.
Sat Dec 26, 2015 5:10 pm
Re: Honeywell API
Glad you got it sorted. Presumably your TRV's are also bound to the Controller.
Colin
