Plugin Exception
Sat Aug 23, 2014 2:07 pm
nlagaros offline
Re: Plugin Exception
I see a dump of all states, but not a dump from the Honeywell site. If you go to Action Groups and create a new one for your device, you should see one called Dump JSON.
Sat Aug 23, 2014 3:41 pm
jalves offline
OK, I think I understand now. Here's a dump when I do that:
 Aug 23, 2014, 5:40:11 PM
  Enabling plugin "Honeywell 0.1.1"
  Starting plugin "Honeywell 0.1.1" (pid 23485)
  Started plugin "Honeywell 0.1.1"
  Honeywell                       Your plugin version, v0.1.1, is current.
  Honeywell                       Saved Plugin Configuration
  Honeywell                       [AC Heat]: RawMessage: 5850177427070526141
Aug 23, 2014, 5:40:39 PM
  Action Group                    Thermo test
  Honeywell                       {
    "alerts": "\r\n",
    "communicationLost": false,
    "deviceLive": true,
    "latestData": {
        "canControlHumidification": false,
        "drData": {
            "CoolSetpLimit": 0,
            "DeltaCoolSP": -0.01,
            "DeltaHeatSP": -0.01,
            "HeatSetpLimit": 0,
            "Load": 127.5,
            "OptOutable": false,
            "Phase": -1
        "fanData": {
            "fanMode": 0,
            "fanModeAutoAllowed": true,
            "fanModeCirculateAllowed": false,
            "fanModeFollowScheduleAllowed": false,
            "fanModeOnAllowed": true
        "hasFan": true,
        "uiData": {
            "BatteryStatus": 0,
            "Commercial": false,
            "CoolLowerSetptLimit": 50.0,
            "CoolNextPeriod": 88,
            "CoolSetpoint": 75.0,
            "CoolUpperSetptLimit": 99.0,
            "Deadband": 3.0,
            "DeviceID": 521607,
            "DispTemperature": 75.0,
            "DispTemperatureAvailable": true,
            "DispTemperatureStatus": 0,
            "DisplayedUnits": "F",
            "DualSetpointStatus": false,
            "HeatLowerSetptLimit": 40.0,
            "HeatNextPeriod": 88,
            "HeatSetpoint": 65.0,
            "HeatUpperSetptLimit": 90.0,
            "HoldUntilCapable": true,
            "IndoorHumidStatus": 128,
            "IndoorHumidity": 128.0,
            "IndoorHumiditySensorAvailable": false,
            "IndoorHumiditySensorNotFault": true,
            "IsInVacationHoldMode": false,
            "OBPolarity": 0,
            "OutdoorHumidStatus": 128,
            "OutdoorHumidity": 128.0,
            "OutdoorHumidityAvailable": false,
            "OutdoorTemp": 128.0,
            "OutdoorTempStatus": 128,
            "OutdoorTemperatureAvailable": false,
            "RawMessageID": 5850177427070526141,
            "SchedCoolSp": 75.0,
            "SchedHeatSp": 65.0,
            "ScheduleCapable": true,
            "SenseFromHereAllowed": false,
            "SensorAveraging": false,
            "SetpointChangeAllowed": true,
            "SouthernAwayAllowed": false,
            "StatSenseDispTemp": 75.0,
            "StatusCool": 1,
            "StatusHeat": 1,
            "SwitchAutoAllowed": true,
            "SwitchCoolAllowed": true,
            "SwitchEmergencyHeatAllowed": true,
            "SwitchHeatAllowed": true,
            "SwitchOffAllowed": true,
            "SystemSwitchPosition": 5,
            "TemporaryHoldUntilTime": 1320,
            "ThermostatLocked": false,
            "TimeOfDayFlag": 0,
            "UIDataID": 31495981,
            "VacationHold": 0,
            "VacationHoldUntilTime": 0
        "weather": {
            "HasStation": true,
            "Humidity": "54",
            "Icon": "10A_chance_of_thunderstorm%402x",
            "Phrase": "Mostly cloudy w/ t-storms",
            "Temperature": "92"
    "success": true
  Honeywell Error                 Honeywell warning: waiting for command execution [0]
Running Indigo 7.4.1 on a 27" iMac (mid-2017), 40G memory, 1T Fusion Drive, OS X 10.15.4
Jeff
Tue Sep 09, 2014 9:18 am
jalves offline
After several weeks of working well, I'm suddenly seeing a log full of errors. Looks like something happened about 11:00 pm last night. Here's a snippet of what I'm seeing.
  File "plugin.py", line 49, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Honeywell.indigoPlugin/Contents/Server Plugin/Honeywell.py", line 78, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Honeywell.indigoPlugin/Contents/Server Plugin/Honeywell.py", line 166, in get_all
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Honeywell.indigoPlugin/Contents/Server Plugin/Honeywell.py", line 218, in get_one
  File "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoPluginHost.app/Contents/PlugIns/simplejson/__init__.py", line 307, in loads
  File "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoPluginHost.app/Contents/PlugIns/simplejson/decoder.py", line 335, in decode
  File "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoPluginHost.app/Contents/PlugIns/simplejson/decoder.py", line 353, in raw_decode
<type 'exceptions.ValueError'>: No JSON object could be decoded
  Honeywell Error                 plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
  Schedule                        Poll Honeywell
  Honeywell Error                 Bad R3 status: 401:Unauthorized
  Honeywell Error                 Error in plugin execution runConcurrentThread:
Jeff
Thu Sep 11, 2014 10:44 am
nlagaros offline
Bad news - looks like Honeywell changed something with their website to prevent access (for now). I've read that others that have coded to interface with the Total Comfort site are experiencing the same problems. I hope to find out soon how to adjust this plugin to work again. For now, out of luck. :(
Thu Sep 11, 2014 11:06 am
jalves offline
That's what I thought too. Darn.
Appreciate your work on it.
Jeff
Sat Sep 13, 2014 3:04 am
nlagaros offline
I just posted an update. It is working for me. Honeywell updated their login authentication slightly. They also removed some outdoor weather reporting which stinks.
Sat Sep 13, 2014 5:59 am
jalves offline
Thanks for this. I'm going to be away for almost two weeks so I won't be able to try the update for a while. Will report when I get back.
Jeff
Wed Sep 17, 2014 11:08 am
nlagaros offline
Just posted another update with further fixes. Hopefully this will stick for a while.
