Can someone send me the plugin
Wed Aug 01, 2018 3:18 pm
Sevilsivle offline
Re: Can someone send me the plugin
http://www.automatedhome.co.uk/vbulleti ... aintenance
Perhaps this explains the error message?
Fri Aug 03, 2018 7:14 am
kidney offline
I wish it was that, but it never worked for me....
Fri Nov 23, 2018 4:01 pm
kidney offline
Anyone can help me with this, still hoping to connect to my Honeywell account
Honeywell [Wed Aug 1 06:22:14 2018] Token Error: {"error":"invalid_grant"}
What does invalid grant mean?
Fri Nov 23, 2018 4:26 pm
It means the authentication to the Honeywell servers is failing.
Fri Nov 23, 2018 4:35 pm
kidney offline
Thanks found the login problem.... Now if I could get it to read my Prestige IAQ thermostat.
Wed Nov 28, 2018 2:03 pm
kidney offline
RogueProeliator wrote:
How are you doing that?
I have the Prestige IAQ Thermostat..
So I just noticed this post, over a month late, while digging in to something else... I really do apologize for that.
Setup was actually fairly simple - I purchased the RedLink Gateway, included it in the A/C's wireless communications network via the thermostat and created a login on the internet. Obviously if your thermostat can talk directly you are one up on mine... then just configured the plugin with login credentials and was off.
FWIW, I bought the gateway on eBay for much lower than the cost they want from the distributor.
Adam
Where did you find you MAC address on the RedLink bridge?
Wed Nov 28, 2018 2:23 pm
kidney offline
This is what I'm getting now when it's time to retrieve the info from my thermostat...
Nov 28, 2018 at 3:21:34 PM
   Honeywell Debug                 Stopping device: Thermostat
   Honeywell Debug                 Starting device: Thermostat
   Honeywell Debug                 [Wed Nov 28 15:21:34 2018] Thermostat: Thermostat, Enabled: True
   Honeywell                       Initializing thermostat device: Thermostat
   Honeywell Debug                 Updating Device: Thermostat, State: maxCoolSetpoint, Value:
   Honeywell Debug                 Updating Device: Thermostat, State: maxHeatSetpoint, Value:
   Honeywell Debug                 Updating Device: Thermostat, State: minCoolSetpoint, Value:
   Honeywell Debug                 Updating Device: Thermostat, State: minHeatSetpoint, Value:
   Honeywell Debug                 [Wed Nov 28 15:21:34 2018] Cannot read device data for: Thermostat
   Honeywell Debug                 [Wed Nov 28 15:21:36 2018] Cannot read device data for: Thermostat
   Honeywell Error                 [Wed Nov 28 15:21:36 2018] Failed to retrieve thermostat status for: Thermostat
