Onkyo TX-NR575 - STRMBOX input
Thu Oct 01, 2020 11:04 pm
srkinard offline
I've been using this plugin to control my Onkyo TX-NR575 unit, but the one thing it doesn't have is a mapping for the HDMI input called STRMBOX. This is what I have my Roku connected to and I'd really love it if I could add this input selection to my Indigo Control Pages.
I tried every single input available in the popup list, but none of them connect that that hardware port on the device.
The onkyo-eiscp/eiscp-commands.yaml repository seems to mark this as input 11...but I don't know enough about the plugin to try and modify it.
      '11':
        description: sets STRM BOX
        models: set1
Any chance to get this in there? or how I could modify the plugin myself to do it?
Ross
Sat Nov 14, 2020 8:15 pm
RogueProeliator offline
Re: Onkyo TX-NR575 - STRMBOX input
Soooo... only a month late seeing this as I go back checking forums for missed posts - my sincere apologies! I am making a new version at the present time and will send you a link to a pre-release version to try out that has this input enabled. Unfortunately I can't test this and will have to take a guess at the return value until you can verify (the YAML is usually accurate but there are discrepancies here and there).
I expect that to be ready this evening or tomorrow.
Adam
Sat Nov 14, 2020 8:40 pm
srkinard offline
Thanks Adam!
No worries and no rush...it's really nice to have the control I do on the receiver. I wish I had picked up a second one for a different room, but sadly they are not available anymore.
I paid about $250 for this one and I certainly can't find any close to it for less than $400.
Ross
Sat Nov 14, 2020 8:43 pm
Okay, I lied... there wasn't enough in there for me to properly update Indigo with the return value... but we can get that from your received. If you would:
1. Put the receiver on the proper input
2. Turn on Full Debug for the Onkyo plugin (via the Plugin Config dialog)
3. Go to the Send Arbitrary Command dialog from the menu Plugins -> Onkyo Network Remote Plugin -> Send Arbitrary Command
4. Select your receiver and enter SLIQSTN as the command and send.
5. Check the logs - you should see the response from this command...
6. Toggle Debug Off
If you can send me the response that you get, I can pretty easily get you going (famous last words... ?)
Adam
Sat Nov 14, 2020 8:46 pm
srkinard offline
Here you go:
Nov 14, 2020 at 8:44:53 PM
   Onkyo Network Remote Plugin     Debug enabled (on Low) by user
   Onkyo Network Remote Plugin Debug Sending eISCP Command: SLIQSTN
   Onkyo Network Remote Plugin Debug Effect execution: Calling function inputSelectorQueryReceived
   Onkyo Network Remote Plugin Debug Updating current input number/label: 11 / STRM
Nov 14, 2020 at 8:45:31 PM
   Onkyo Network Remote Plugin     Debug disabled by user
Let me know if you need more info.
Ross
Sat Nov 14, 2020 10:05 pm
Can you give this a try when you get a few moments to test it out? This is a pre-release of the next version for testing...
https://github.com/RogueProeliator/IndigoPlugins-Onkyo-Receiver-Network-Remote/releases/tag/v2.4.1-rc1
If this does not work, best would be the full plugin log (it is located in the Logs directory in your Indigo Server install, named by the plugin name). You can either post it if not too large or send me a PM and I'll send you my email to send it that way.
Adam
Sun Nov 15, 2020 9:33 am
srkinard offline
Hey Adam...installed it and tried to configure one of my control pages to add that input, but it doesn't show up in the list-
Here's where I reloaded the plugin to confirm version, then I did an output of the Onkyo device in case it helps any:
Nov 15, 2020 at 9:21:37 AM
   Reloading plugin "Onkyo Network Remote Plugin 2.1.4"
   Stopping plugin "Onkyo Network Remote Plugin 2.1.4" (pid 60529)
   Stopped plugin "Onkyo Network Remote Plugin 2.1.4"
   Starting plugin "Onkyo Network Remote Plugin 2.1.4" (pid 60600)
   Started plugin "Onkyo Network Remote Plugin 2.1.4"
Nov 15, 2020 at 9:24:25 AM
   Onkyo Network Remote Plugin     Dumping details for DeviceID: 1460687988
   Onkyo Network Remote Plugin     address : 192.168.100.80:60128
batteryLevel : None
buttonGroupCount : 0
configured : True
description :
deviceTypeId : onkyoReceiverNetworkRemoteDevice
displayStateId : connectionState
displayStateImageSel : SensorOn
displayStateValRaw : Connected
displayStateValUi : Connected
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 1170212817
     com.duncanware.onkyoNetworkRemote : (dict)
          address : 192.168.100.80:60128 (string)
          deviceInputsConnected : (list)
               Item : 25 (string)
               Item : 23 (string)
               Item : 10 (string)
               Item : 24 (string)
               Item : 07 (string)
               Item : 08 (string)
               Item : 09 (string)
               Item : 28 (string)
               Item : 30 (string)
               Item : 27 (string)
               Item : 2B (string)
               Item : 22 (string)
               Item : 32 (string)
               Item : 20 (string)
               Item : 21 (string)
               Item : 26 (string)
               Item : 12 (string)
               Item : 2A (string)
               Item : 2C (string)
               Item : 29 (string)
               Item : 40 (string)
               Item : 00 (string)
               Item : 01 (string)
               Item : 02 (string)
               Item : 03 (string)
               Item : 04 (string)
               Item : 05 (string)
               Item : 06 (string)
               Item : 31 (string)
          deviceZonesConnected : (list)
               Item : main (string)
          ipAddress : 192.168.100.80 (string)
          onkyoReceiversFound : 192.168.100.80:60128 (string)
          portNumber : 60128 (string)
          stateDisplayColumnState : connectionState (string)
          updateInterval : 90 (string)
lastChanged : 2020-11-15 09:23:32
lastSuccessfulComm : 2020-11-15 09:23:32
model : Onkyo Receiver
ownerProps : com.duncanware.onkyoNetworkRemote : (dict)
          Item : 25 (string)
          Item : 23 (string)
          Item : 10 (string)
          Item : 24 (string)
          Item : 07 (string)
          Item : 08 (string)
          Item : 09 (string)
          Item : 28 (string)
          Item : 30 (string)
          Item : 27 (string)
          Item : 2B (string)
          Item : 22 (string)
          Item : 32 (string)
          Item : 20 (string)
          Item : 21 (string)
          Item : 26 (string)
          Item : 12 (string)
          Item : 2A (string)
          Item : 2C (string)
          Item : 29 (string)
          Item : 40 (string)
          Item : 00 (string)
          Item : 01 (string)
          Item : 02 (string)
          Item : 03 (string)
          Item : 04 (string)
          Item : 05 (string)
          Item : 06 (string)
          Item : 31 (string)
pluginId : com.duncanware.onkyoNetworkRemote
pluginProps : com.duncanware.onkyoNetworkRemote : (dict)
          Item : 25 (string)
          Item : 23 (string)
          Item : 10 (string)
          Item : 24 (string)
          Item : 07 (string)
          Item : 08 (string)
          Item : 09 (string)
          Item : 28 (string)
          Item : 30 (string)
          Item : 27 (string)
          Item : 2B (string)
          Item : 22 (string)
          Item : 32 (string)
          Item : 20 (string)
          Item : 21 (string)
          Item : 26 (string)
          Item : 12 (string)
          Item : 2A (string)
          Item : 2C (string)
          Item : 29 (string)
          Item : 40 (string)
          Item : 00 (string)
          Item : 01 (string)
          Item : 02 (string)
          Item : 03 (string)
          Item : 04 (string)
          Item : 05 (string)
          Item : 06 (string)
          Item : 31 (string)
protocol : Plugin
remoteDisplay : True
states : States : (dict)
     connectionState : Connected (string)
     currentInputLabel : STRMBOX (string)
     currentInputNumber : 11 (string)
     hdmiAudioOut : off (on/off bool)
     isConnected : true (string)
     isMuted : false (bool)
     isPoweredOn : true (bool)
     isPoweredOn.ui : On (string)
     listeningMode : all-ch-stereo (string)
     masterVolumeLevel : 62 (integer)
     networkPlayAlbum :   (string)
     networkPlayArtist :   (string)
     networkPlayStatus : Sxx (string)
     networkPlayTitle :   (string)
     sleepTimer : 0 (integer)
     speakerAPower : off (on/off bool)
     speakerBPower : off (on/off bool)
     tunerFrequency : 00530 (string)
     videoOutputResolution :  (string)
     videoPictureMode :  (string)
     videoWideScreenMode :  (string)
     zone2InputLabel :  (string)
     zone2InputNumber :  (string)
     zone2PoweredOn : false (bool)
     zone2VolumeLevel : 0 (integer)
subModel :
supportsAllOff : False
supportsStatusRequest : False
version : None
Ross
Sun Nov 15, 2020 2:31 pm
I'm guessing you forgot to edit the Onkyo Receiver Device and select that as one of the connected inputs... ?
Sun Nov 15, 2020 2:39 pm
srkinard offline
Sigh...yup
Wed Nov 18, 2020 3:41 pm
srkinard offline
Got busy with work and forgot to come back and say thanks again to Adam for the update.
Works like a charm now!
