Plugin not working after v7 install
Sat Dec 24, 2016 12:39 pm
bkmar1192 offline
I am getting the following:
Dec 24, 2016, 10:35:28 AM
Onkyo Network Remote Plugin Debug Plugin preferences updated
Reloading plugin "Onkyo Network Remote Plugin 1.8.19"
Stopping plugin "Onkyo Network Remote Plugin 1.8.19" (pid 92731)
Onkyo Network Remote Plugin Debug Entering deviceStopComm for Onkyo Recevier; ID=1019474725
Onkyo Network Remote Plugin Debug Initiating shutdown of communications with Onkyo Recevier
Onkyo Network Remote Plugin Debug Shutdown of communications with Onkyo Recevier complete
Onkyo Network Remote Plugin Debug Exiting deviceStopComm for Onkyo Recevier
Stopped plugin "Onkyo Network Remote Plugin 1.8.19"
Starting plugin "Onkyo Network Remote Plugin 1.8.19" (pid 92991)
Onkyo Network Remote Plugin Initializing RPFrameworkPlugin
Onkyo Network Remote Plugin Beginning processing of RPFrameworkConfig.xml file
Onkyo Network Remote Plugin Successfully completed processing of RPFrameworkConfig.xml file
Started plugin "Onkyo Network Remote Plugin 1.8.19"
Onkyo Network Remote Plugin Debug Database access has been disabled, skipping connection
Onkyo Network Remote Plugin Debug Entering deviceStartComm for Onkyo Recevier; ID=1019474725
Onkyo Network Remote Plugin Debug Exiting deviceStartComm for Onkyo Recevier
Onkyo Network Remote Plugin Debug Establishing connection to 10.0.1.50
Onkyo Network Remote Plugin Debug Version check initiated
Onkyo Network Remote Plugin Debug Connection established
Onkyo Network Remote Plugin Debug Create connection command de-queued
Onkyo Network Remote Plugin Debug Executing full status update request...
Onkyo Network Remote Plugin Error Error during background processing
Onkyo Network Remote Plugin Your plugin version, v1.8.19, is current.
Onkyo Network Remote Plugin Error Error in plugin execution:
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Onkyo Network Remote.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkTelnetDevice.py", line 199, in concurrentCommandProcessingThread
self.hostPlugin.executeAction(None, indigoActionId=updateStatusPollerActionId, indigoDeviceId=self.indigoDevice.id, paramValues=None)
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Onkyo Network Remote.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkPlugin.py", line 1157, in executeAction
self.indigoActions[indigoActionId].generateActionCommands(self, self.managedDevices[indigoDeviceId], paramValues)
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Onkyo Network Remote.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkIndigoAction.py", line 154, in generateActionCommands
for i in range(0,executeTimes):
TypeError: range() integer end argument expected, got float.
Onkyo Network Remote Plugin Debug Closing connection to device
Sat Dec 24, 2016 1:40 pm
nlagaros offline
Re: Plugin not working after v7 install
I believe there is an updated version of this plugin that supports Indigo 7. Check the announcements topic.
Sat Dec 24, 2016 6:00 pm
