Onkyo Network Remote Feedback and Discussion
Mon Oct 01, 2018 1:52 pm
RogueProeliator offline
Re: Onkyo Network Remote Feedback and Discussion
Maybe this is helpful?
Sort of... well, it should be helpful, but I don't quite understand it. First off, I see why the plugin isn't picking up the tuner frequency - your Onkyo is sending it back a bit different than others. Which is fine, I can accommodate that. However, I don't fully understand the number they are sending back. See these lines:
   Onkyo Network Remote Plugin Debug Received direct tune action to 089.30
   Onkyo Network Remote Plugin Debug Sending tune command for 08930
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('tuning', 35120)
   Onkyo Network Remote Plugin Debug Sending tune command for 09230
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('tuning', 37424)
I have no idea how to interpret that return value.
08930 comes back as 35120... anyone see any obvious translation that I may be missing? Normally these Onkyo values come back as base-10 OR base-16, but this is not either.
Thu Nov 15, 2018 1:08 am
@hamw... can you execute this against your Onkyo receiver via the Plugins -> Onkyo Network Remote -> Send Arbitrary Command menu option?
TUNQSTN
Make sure you have full debug turned on when you do. I am interested in seeing if it returns the same format as when we get a response after setting the tuning.
Adam
Tue Feb 26, 2019 9:14 pm
jbinder offline
Re: Onkyo Network Remote State =Error when using Simple Con
Hi - I have this plugin setup on my 7.2 Indigo Server. I am getting the following error when I Power On the receiver using SimpleControl5.5. in iOS. Can anyone help me understand what it means? I can reload the plugin and things work as expected.
Onkyo Network Remote Plugin Error Error during background processing
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/Onkyo Network Remote.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkTelnetDevice.py", line 262, in concurrentCommandProcessingThread
responseText = RPFrameworkUtils.to_unicode(self.readIfAvailable(ipConnection, lineEndingToken, commandResponseTimeout))
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/Onkyo Network Remote.indigoPlugin/Contents/Server Plugin/onkyoNetworkRemoteDevice.py", line 179, in readIfAvailable
return self.readLine(connection, lineEndingToken, commandResponseTimeout)
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/Onkyo Network Remote.indigoPlugin/Contents/Server Plugin/onkyoNetworkRemoteDevice.py", line 164, in readLine
header = eISCP.eISCPPacket.parse_header(header_bytes)
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/Onkyo Network Remote.indigoPlugin/Contents/Server Plugin/eISCP.py", line 206, in parse_header
assert len(bytes) == 16
AssertionError
Tue Mar 05, 2019 12:17 am
Sorry for the long delay... it seems as if something related to the Simple Control is causing the Onkyo to send an invalid eISCP packet; perhaps it isn't using the same protocol but the plugin is interpreting it as such. Do you have to restart the plugin for it to resume? I can try to code around that so that the plugin ignores it instead of throwing the error.
Adam
Wed Mar 06, 2019 6:48 pm
jbinder offline
I can reload the plug-in and it works fine.
