Onkyo Network Remote Feedback and Discussion
Wed Mar 21, 2018 9:49 pm
RogueProeliator offline
Re: Onkyo Network Remote Feedback and Discussion
I turned on debug logging and I can see it get's an command for input-selector 18, but I guess that's not mapping to anything?
That isn't a known/valid option according to my documentation. :-) I may be able to add it in fairly easily though... can you use the Plugin menu to send this command and see if it changes to that TV input (not the description since it isn't a mapping, but if it will execute the change of the Onkyo's input): SLI18
Adam
Thu Mar 22, 2018 1:50 pm
mbordas offline
Well, sending SLI18 didn't work, so I starting trying other numbers and found that SLI12 does the trick:
   Onkyo Network Remote Plugin Threaddebug Command queue has 1 command(s) waiting
   Onkyo Network Remote Plugin Debug Sending eISCP Command: SLI12
   Onkyo Network Remote Plugin Threaddebug Send command completed.
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('input-selector', 18)
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('listening-mode', 'theater-dimensional')
   Onkyo Network Remote Plugin Threaddebug Found response match: listeningModeQuery
   Onkyo Network Remote Plugin Debug Effect execution: Update state "listeningMode" to "theater-dimensional"
That's confusing, why would it call it input-selector 18, but the command is 12?
Thu Mar 22, 2018 2:39 pm
Because it was built by hardware engineers alone... :lol:
Thu Mar 22, 2018 4:32 pm
Sounds like something a software engineer would say..
Thu Mar 22, 2018 4:43 pm
Yep, because we always know better than those nerds...
Thu Mar 22, 2018 6:20 pm
FlyingDiver online
All the trash talk notwithstanding, you do realize that 18 decimal = 12 hex?
Thu Mar 22, 2018 9:53 pm
So this is interesting... as others have pointed out, all numbers in the Onkyo protocol use hexadecimal; that isn't the interesting part, what is interesting is that normally they come back in hex too, so it is returning a standard integer in base 10 but requiring it to be sent in base 16. This is completely different than their other messages but hey we can work with it. I'll add it to the plugin - this is considered a TV input or is that a label you gave it?
Adam
Fri Mar 23, 2018 8:38 am
As I said - hardware engineers... :lol:
Fri Mar 23, 2018 9:42 pm
I tried both those commands and could not initiate an Internet radio stream. For the more, I upgraded to the new plug-in version and now my FM/a.m. radio selection no longer works. Any thoughts? Also, regarding the Internet radio thing, the plug-in has source selection etc.… Is it possible to add “play“ and “pause” functions so that Internet radio streams can be started and paused?
Okay, so the docs on this are horrible, but I found a couple of other possibilities... Give these a try via the Send Arbitrary Command feature:
NTCPLAY
NTCSTOP
NTC1 ... NTC2... NTC3 (see if these are the presets)
NTC01 ... NTC02 (or see if these are the presets)
I found a slight formatting issue with tuning - try tuning with a full station number, for instance 5 digits for AM (use 01150 instead of just 1150). This will be fixed in the next version, just might give you a working changer now. HOWEVER, my receiver is now sending back an unintelligible value for the currently tuned station. This must have changed in a firmware update at some point, but I can't figure it out right now as it is just some integer that doesn't obviously correspond to the station tuned. Still looking into that.
Adam
Fri Mar 23, 2018 9:43 pm
This will be available in the next version... I double checked and it is not listed as a valid input number in any of the open source repos out there that use the eISCP commands - is this a newer receiver or something?
Adam
Sat May 12, 2018 6:02 pm
Different Computers offline
Can't say for sure, as I searched for this model here and came up with nothing, butthis likely works with this plugin.
On sale for $60 off right now.
Sun May 13, 2018 9:10 pm
Yeah, I would expect that model to work - similar ones are known to and, in fact, nearly all of their receivers are compatible... Onkyo has been pretty good about compatibility.
Adam
Tue Sep 11, 2018 8:47 pm
hamw offline
Plugin is working fine except the tuner frequency does not update. The plugin will switch AM, FM and tune channels as seen on the unit itself, but will not update the tuner frequency in the little dialog box at the bottom of the Indigo device page. As such it does not update on the control page either. Used to work....
Thoughts?
Here's a debug log with some station changes.
Onkyo Network Remote Plugin     Debug enabled (on Low) by user
   Onkyo Network Remote Plugin Debug Sending eISCP Command: SLZ26
   Onkyo Network Remote Plugin Debug Sending eISCP Command: SLZ25
   Onkyo Network Remote Plugin Debug Effect execution: Calling function zone2SelectorQueryReceived
   Onkyo Network Remote Plugin Debug Updating zone 2 input number/label: 25 / AM
   Onkyo Network Remote Plugin Debug Received direct tune action to 089.30
   Onkyo Network Remote Plugin Debug Sending tune command for 08930
   Onkyo Network Remote Plugin Debug Updating zone 2 input number/label: 24 / FM
   Onkyo Network Remote Plugin Debug Received direct tune action to 092.30
   Onkyo Network Remote Plugin Debug Sending tune command for 09230
   Onkyo Network Remote Plugin Debug Received direct tune action to 97.5
   Onkyo Network Remote Plugin Debug Sending tune command for 09750
   Onkyo Network Remote Plugin Debug Executing full status update request...
   Onkyo Network Remote Plugin Debug Sending eISCP Command: PWRQSTN
   Onkyo Network Remote Plugin Debug Effect execution: Update state "isPoweredOn" to "True" with UIValue "On"
   Onkyo Network Remote Plugin Debug Effect execution: Calling function updateVirtualMasterVolume
   Onkyo Network Remote Plugin Debug Sending eISCP Command: MVLQSTN
   Onkyo Network Remote Plugin Debug Sending eISCP Command: AMTQSTN
   Onkyo Network Remote Plugin Debug Sending eISCP Command: HAOQSTN
   Onkyo Network Remote Plugin Debug Effect execution: Update state "masterVolumeLevel" to "81"
   Onkyo Network Remote Plugin Debug Sending eISCP Command: SLIQSTN
   Onkyo Network Remote Plugin Debug Effect execution: Update state "isMuted" to "False"
   Onkyo Network Remote Plugin Debug Sending eISCP Command: SPAQSTN
   Onkyo Network Remote Plugin Debug Sending eISCP Command: SPBQSTN
   Onkyo Network Remote Plugin Debug Sending eISCP Command: SLPQSTN
   Onkyo Network Remote Plugin Debug Sending eISCP Command: HDOQSTN
   Onkyo Network Remote Plugin Debug Effect execution: Update state "hdmiAudioOut" to "False"
   Onkyo Network Remote Plugin Debug Sending eISCP Command: RESQSTN
   Received INSTEON                "Thermostat MBR" temperature changed to 69.0
   Onkyo Network Remote Plugin Debug Sending eISCP Command: VWMQSTN
   Onkyo Network Remote Plugin Debug Sending eISCP Command: VPMQSTN
   Onkyo Network Remote Plugin Debug Sending eISCP Command: LMDQSTN
   Onkyo Network Remote Plugin Debug Sending eISCP Command: SLAQSTN
   Onkyo Network Remote Plugin Debug Sending eISCP Command: TUNQSTN
   Onkyo Network Remote Plugin Debug Sending eISCP Command: NATQSTN
   Onkyo Network Remote Plugin Debug Sending eISCP Command: NALQSTN
   Onkyo Network Remote Plugin Debug Sending eISCP Command: NTIQSTN
   Onkyo Network Remote Plugin Debug Effect execution: Update state "listeningMode" to "stereo"
   Onkyo Network Remote Plugin Debug Sending eISCP Command: NSTQSTN
   Onkyo Network Remote Plugin Debug Effect execution: Update state "networkPlayArtist" to "BBC World Service News"
   Onkyo Network Remote Plugin Debug Effect execution: Update state "networkPlayAlbum" to "London, United Kingdom"
   Onkyo Network Remote Plugin Debug Sending eISCP Command: ZPWQSTN
   Onkyo Network Remote Plugin Debug Sending eISCP Command: SLZQSTN
   Onkyo Network Remote Plugin Debug Effect execution: Update state "networkPlayTitle" to "World News"
   Onkyo Network Remote Plugin Debug Sending eISCP Command: ZVLQSTN
   Onkyo Network Remote Plugin Debug Effect execution: Update state "videoOutputResolution" to "through"
   Onkyo Network Remote Plugin Debug Effect execution: Update state "networkPlayStatus" to "Pxx"
   Onkyo Network Remote Plugin Debug Effect execution: Calling function inputSelectorQueryReceived
   Onkyo Network Remote Plugin Debug Updating current input number/label: 2B / NETWORK, NET
   Onkyo Network Remote Plugin Debug Effect execution: Update state "speakerAPower" to "False"
   Onkyo Network Remote Plugin Debug Effect execution: Update state "speakerBPower" to "False"
   Onkyo Network Remote Plugin Debug Effect execution: Update state "videoWideScreenMode" to "auto"
   Onkyo Network Remote Plugin Debug Effect execution: Update state "zone2PoweredOn" to "True" with UIValue "On"
   Onkyo Network Remote Plugin Debug Effect execution: Update state "zone2VolumeLevel" to "0"
   Onkyo Network Remote Plugin Debug Effect execution: Calling function updateVirtualZone2Volume
******************************* some errors...
  Onkyo Network Remote Plugin Debug Sending eISCP Command: PWR00
   Onkyo Network Remote Plugin Debug Failed to parse eISCP message, message ignored: !1NLT0E22000000000001000E00
   Onkyo Network Remote Plugin Debug Effect execution: Update state "isPoweredOn" to "False" with UIValue "Standby"
   Onkyo Network Remote Plugin Debug Effect execution: Update state "networkPlayStatus" to "Sxx"
   Onkyo Network Remote Plugin Debug Sending eISCP Command: PWR01
   Onkyo Network Remote Plugin Debug Failed to parse eISCP message, message ignored: !1NMSMxxxxx20E
Tue Sep 11, 2018 9:17 pm
It is possible an update broke the parsing expression or something... we will need to see the actual data being received back from the device whenever the plugin queries for the frequency. You can either turn the debugging up to full ( above what you posted, I believe) and search for it OR that data should already available in the plugin's log file; should be at:
/Library/Application Support/Perceptive Automation/Indigo 7/Logs/com.duncanware.onkyoNetworkRemote
We are looking for a response that looks something like:
('tuning', '102.50')
Fri Sep 21, 2018 5:11 pm
hamw offline
Sep 21, 2018, 7:08:06 PM
   Onkyo Network Remote Plugin Debug Plugin preferences updated
   Onkyo Network Remote Plugin     Debugging enabled... remember to turn off when done!
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:01/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:02/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:03/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:04/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:05/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:06/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:07/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:08/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:09/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:10/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:11/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:12/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Execute condition failed, skipping execution for command: directTune
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('tuning', 35120)
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:13/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:14/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:15/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:16/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:17/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received: ('net-usb-time-info', '00:01:18/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:18/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('tuning', 37424)
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:19/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:20/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:21/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:22/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:23/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:24/--:--:--')
   Onkyo Network Remote Plugin Debug Received direct tune action to 090.10
   Onkyo Network Remote Plugin Debug Sending tune command for 09010
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:25/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('tuning', 36880)
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:26/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:27/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:28/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:29/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:30/--:--:--')
   Onkyo Network Remote Plugin Debug Received direct tune action to 091.10
   Onkyo Network Remote Plugin Debug Sending tune command for 09110
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('tuning', 37136)
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:31/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:32/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:33/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:34/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:35/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:36/--:--:--')
   Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-time-info', '00:01:37/--:--:--')
Maybe this is helpful?
