Installed the plugin and went to configure my receivers-- I have 4. Two of them went fine, and I get the following errors on the other two:
Onkyo Network Remote Plugin Error Error in plugin execution:
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Onkyo Network Remote.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkTelnetDevice.py", line 215, in concurrentCommandProcessingThread
responseText = self.readLine(ipConnection, lineEndingToken, commandResponseTimeout)
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Onkyo Network Remote.indigoPlugin/Contents/Server Plugin/onkyoNetworkRemoteDevice.py", line 139, in readLine
self.hostPlugin.logDebugMessage("Failed to parse eISCP message, message ignored: %s".str(message), RPFramework.RPFrameworkPlugin.DEBUGLEVEL_LOW)
AttributeError: 'str' object has no attribute 'str'
The 2 that worked are NR-TX515 and NR-TX515. The two that didn't are NR-TX-414 and NR-TX3008. I have a couple of iOs apps and both of those work with them,
I'm now going to test the two that do work and see what happens.... Thanks for doing this!
Any thoughts?
