Re: Autelis Jandy
Posted: Sat Jun 01, 2013 5:40 pm
BTW, I was going thru the actions and the pool cleaner toggle was not working. I added a "#" in front of "CLEANR" and it worked again.
Also, I just tried the AquaPure "Set" function, monitoring with the web interface. The first time I tried it, it went into "equipment on/off" and the menu just kept scrolling. After I clicked "Select" on the web interface keypad, the proper macro executed and it found the AquaPure menu selection and correctly set it. It did not exit back out of the AquaPure menu, and I had to do that manually with the "back" button.
On several subsequent tries it executed correctly, but I still had to click the "back" button to get out of the "menu/help" menu so that the status lines would update correctly.
- Code: Select all
Error (client) Action couldn't be found - the plugin supplying the action may be disabled or missing
- Code: Select all
elif action == "Cleaner":
setting = pluginAction.props.get("setting")
if setting == "Off":
outmsg = ("#CLEANR=0")
elif setting == "On":
outmsg = ("#CLEANR=1")
elif setting == "Toggle":
outmsg = ("#CLEANR") <--- HERE
self.sendMessage(outmsg)
