Page 2 of 3
Re: TED5000 - The Energy Detective
Posted:
Wed Jan 01, 2014 1:31 am
by nlagaros
This is exactly what I need to know to pinpoint the issue. I had a typo - actually 2 in the code that parses the XML file for MTU4. I just updated my wiki with v1.0.4 which should fix all this. Great catch! Thanks!
bda wrote:Hello Nick;
I think the bug is with TED and that their XML is reporting back <float> as an element and not <float>.
Perhaps this is something you could see if you can work around.
What is important is that when I change the # of MTUs from 4 to 3 it appears to work!
It looks like an error with the TED software on the 4'th MTU.
Separately, I noticed that the TED unit can't resolve system time when I have 4 MTUs. Their software (TED's) is a bit buggy with more than 3 MTUs and it looks like it extends to their reporting.
I appreciate your plugin and support. Happy New Year
Posted:
Wed Jan 01, 2014 1:32 am
by nlagaros
I just posted a new version that should take care of this issue. Please give it a shot. Thanks.
Bollar wrote:I just found this plug-in. Thanks!
I have an error on start-up that appears to let the plug-in update only once then stop:
- Code: Select all
Starting plugin "TED 5000 Plugin 1.0.3" (pid 1251)
Started plugin "TED 5000 Plugin 1.0.3"
TED 5000 Plugin Your plugin version, v1.0.3, is current.
TED 5000 Plugin Error exception in deviceStartComm(TED 5000): global name 'flaot' is not defined
TED 5000 Plugin Polling Interval: 5
Hopefully it's not just me.
Posted:
Wed Jan 01, 2014 3:31 pm
by bda
Working great
Posted:
Thu Jan 02, 2014 8:40 am
by Bollar
Very good. Thanks for the fix!
Posted:
Fri Feb 21, 2014 5:41 pm
by midd
I'm not seeing the plug-in states in the display window. The only data I see is the real time KW usage.
Posted:
Tue Jun 24, 2014 9:23 am
by nlagaros
Are you still having an issue? You need to scroll down the lower panel in Indigo to see all of the custom states.
midd wrote:I'm not seeing the plug-in states in the display window. The only data I see is the real time KW usage.
Posted:
Sat Nov 08, 2014 4:16 pm
by sumocomputers
Was trying to download this plugin from
https://vulture.lagaros.com/wiki/projec ... ation.htmlAnd under TED5000, there doesn't seem to be any download available.
Any plans to put a download link back up?
Also, any plans to support TED Pro Home? I am actually wondering if the TED5000 plugin might even work with TED Pro Home.
Chris
Posted:
Sun Nov 09, 2014 7:45 am
by nlagaros
Looks like I'm having wiki issues. You can download from the following link:
http://vulture.lagaros.com/IndigoPlugins/TED5000/TED5000.indigoPlugin_1.0.5.zipI'm not sure how it will work with TED Pro Home, but guessing that some of it would. I would need to see the XML file generated and could then adjust the plugin.
sumocomputers wrote:Was trying to download this plugin from
Chris
Posted:
Sun Nov 09, 2014 10:21 am
by sumocomputers
You are correct, the plugin does not work with TED Home Pro (TED6000).
I have no luck using the TED5000 API calls, and they haven't posted their TED6000 API docs, so I have requested this. Hopefully this will allow us to see the XML output.
I do know that some online services (like Bidgely, which is awesome BTW), only supports POST not POLL for TED6000, but they support both for TED5000. No idea if this is because TED6000 doesn't support POLL, or something else.
Am I correct in assuming that an Indigo plugin needs to use POLL?
Posted:
Sun Nov 09, 2014 10:27 am
by nlagaros
The plugin simply doest an http get to pull an xml page. What you can try is to type the following your browser: http://[ip address of TED]/api/LiveData.xml
See if you get anything returned to you.
sumocomputers wrote:You are correct, the plugin does not work with TED Home Pro (TED6000).
Posted:
Sun Nov 09, 2014 10:39 am
by sumocomputers
Yeah, forgot to say I tried that, and get:
404: File not found
Posted:
Sun Nov 09, 2014 10:46 am
by nlagaros
I took a quick read of the TED support forums for the TED pro and someone reported success with the following url: http://[TED ip address]/api/DashData.xml
Does this work for you?
sumocomputers wrote:Yeah, forgot to say I tried that, and get:
404: File not found
Posted:
Mon Nov 10, 2014 11:16 am
by sumocomputers
Below is the XML output and screenshot attached.
- Code: Select all
<DashData><Now>460</Now><TDY>4435</TDY><MTD>156403</MTD><Avg>13596</Avg><Proj>421506</Proj><Voltage>1198</Voltage><Phase>131</Phase></DashData>
Also, here are the API docs they sent me:
https://www.dropbox.com/s/yykzvnqugl11g ... 140625.pdfhttps://www.dropbox.com/s/ldfx99nn2k5ip ... 5-R607.pdf
Posted:
Mon Nov 30, 2015 7:40 pm
by Ramias
Greetings.
New Indigo user here.
This is a year old. Just checking to see if anybody has written a plugin for TED6000 (Pro). if not I may give it a shot.
Posted:
Tue Dec 01, 2015 12:38 pm
by nlagaros
If I had my hands on one, it would be a bit easier. I am happy to collaborate such that one plugin will support both systems. Let me know.
