Indigo v7 and TED v2.0.0 plugin gives errors on polling
Sun Apr 02, 2017 7:59 am
dstrickler offline
I'm getting these errors since upgrading both Indigo and the TED plugin. I've tried rebooting and re-installing. Anyone have a clue?
Error                           device "TED5000" state key curEnergyLevel not defined (ignoring update request)
Error                           device "TED5000" state key accumEnergyTotal not defined (ignoring update request)
Dave
Sun Apr 16, 2017 7:10 am
deadsquid offline
Re: Indigo v7 and TED v2.0.0 plugin gives errors on polling
Reconfigure your TED device (e.g. Select the TED device in the DEVICES section of Indigo) and make sure the Model is updated to 5000. If that doesn't correct it, delete the existing device and re-add it (if you have to go this route, you'll need to check anything that used that device (control page variables, etc.). The polling errors should disappear.
Sun Apr 16, 2017 11:05 am
deadsquid offline
err... set it to the model you have. :D I had a 5000 and got these errors as well, until I reconfigured the device.
Sun Apr 16, 2017 12:56 pm
dstrickler offline
That did it - thanks!
Dave
